Old 09-22-2002, 11:50 PM   #1
67c-20
Question rochester carb id number
when i bought my 67 3/4 4wd it had a rochester 4bbl on the 327. i would like to rebuild it but i can not find the id number. most of the time it is written on the drivers side of the carb right? where else might it be?
67 k-20 w/327 and a 3speed and 4.57 rear with 17 inch split rims and 9 inch wide rubber(is my current project)
73 blazer 6 inch all spring lift 350/350 with crappy 3.08 gears and 35 inch bfg tires. just put out 135 hp to the wheels on the dyno.
54 chevy delray .060 over 250 i-6 which was taken from my first truck(68 gmc). it is next in line for a rebuild
67c-20 is offline   Reply With Quote
Old 09-23-2002, 09:43 AM   #2
70c10
67-72 Addict!
70c10's Avatar
I think the 4 barrels are on the passenger side.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-23-2002, 12:17 PM   #3
RodC
RodC's Avatar
The quadrajets I have owned were all on the drivers side.
Here are a couple of sites to check out. The first has a pic of where the numbers are:
http://meltingpot.fortunecity.com/th.../rochcode.html
http://www.carbs.net/quadnumber.htm
Rod Childers
'71 C10 Stepside
RodC is offline   Reply With Quote
Old 09-23-2002, 02:43 PM   #4
MStokes
MStokes's Avatar
My quadrajet number is on the driver's side. Also, it is a rochester design that was built by Carter. On the drivers side it is stamped with the words "manufactured for GMC by Carter".
1972 C-10 LWB, 400/350, 2WD
1972 C-20 Custom Camper, 350/350, 4WD (Converted)
MStokes is offline   Reply With Quote
