07-25-2007, 10:26 AM | #1 |
one set closer
changing from 67 to 72 spindle
when doing this do i need the lower and upper ball joints and tie end rods for the 72 spindle.
07-25-2007, 08:18 PM | #2 |
Re: changing from 67 to 72 spindle
as long as you have a haf ton to haf ton youll be sweet if you try and change from 3/4 to haf i dont know the answer yet well hope that helps
07-27-2007, 05:21 PM | #3 |
u need to get the upper and lower ball joints replace if nessceary but u need to replace seals and bearings if needed also regrease and repak bearings this dosent take long iv already done it ALSO REPLACE brake lines if their rotted
07-28-2007, 09:36 AM | #4 |
Dave's not here, man
If you used the inner/outer tie rod ends you'll also need the centerlink. You can use the outer tie rod ends, but you need a sleeve adapter to make them work with the 67 inners.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
07-30-2007, 03:05 PM | #5 |
one set closer
dave2953 If you used the inner/outer tie rod ends you'll also need the centerlink. You can use the outer tie rod ends, but you need a sleeve adapter to make them work with the 67 inners.
where can i get a sleeve adapter. Last edited by UP GRADE; 07-30-2007 at 03:06 PM. |
