Old 07-25-2007, 12:07 PM   #1
60-66 Nut
Professional Beer Tester
Weird Problem With '02 Suburban
Just wondering if anyone has ever ran across this before. Our office manager has an '02 Suburban with the 5.3L V8 and around 80,000 miles. Recently it started a strange noise when reving the engine, upon letting off the accelerator it sounded like the fan was hitting the shroud. We found the fan clutch had some slack so we replaced it, but the noise did not change. After checking it closer, we found the a/c belt tensioner was jumping up and down, hitting the transmission cooler lines. We checked the tensioner and found it was bad, so we put a new tensioner and belt. It still does the same thing. He said he talked to someone on the net who replaced their tensioner several times, and finally replaced the compressor which seems to have cured the problem. They even mentioned a Technical Service Bulletin for the problem. The compressor cools great and makes absolutley no noise, but could it be bad anyway? Any help or replies would be greatly appreciated.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 06-25-2008, 04:36 PM   #2
warthog52
Re: Weird Problem With '02 Suburban
yes, I'm a Chevy Tech and the problem that you discussed is characteristic of an A/C compressor that is slugging, which is a type of drag often caused by oil collecting in it.
Replacing the compressor will normally remedy that problem.
warthog52
warthog52 is offline   Reply With Quote
