07-25-2007, 06:50 PM | #1 |
drop springs help please!!!!!
I need to know how low of a coil drop spring can i put on the front of a 67 stepside without having to change anything? rears also to have a even level look? Thanks bill
07-25-2007, 07:32 PM | #2 | |
Re: drop springs help please!!!!!
I think 3 in the front and 5 in the back look nice and is easy and econimical.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
07-25-2007, 07:35 PM | #3 |
with 3 in the front will i have to get shorter shocks? and in the rear with 5 will i have to c-noch or move the shock mounts?
07-25-2007, 08:28 PM | #4 |
Official Site Guitar Shredder
i dropped my 67 3/5. it is a good idea to run a shorter shock on all corners but . i guess it wouldnt be needed. the stock shock might just run out of travel . and for the 5 inch rear drop. you wont need a c-notch , or change your panhard bar. but anything lower and you might have problems. im thinking that 6 inches in the rear would kick your rearend over and you would have to get an adjustable pan hard bar.< this might apply for springs and blocks also. ?
07-25-2007, 08:38 PM | #5 |
I am a Referee of life.
Most of the members here will recommend a 2 in spring max in front due to the shim stack needed to get the truck aligned after dropping.IIRC using blocks in the rear will affect the panhard less than springs would.i.e.3 in springs and 2 in blocks= no new panhard.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
07-25-2007, 08:44 PM | #6 |
every inch you lower the rear it moves the rear off center!! it doesnt start at 4 or 5 inches its pretty noticable after 3" and for the rear again every little bit you lower it you start to lose the shock angle therefore the effectiveness of the shock is lost anything more than 3" drop in the rear i relocate the shorter shocks and center the rear with an adjustable panhard bar // i've seen guys with 4-5inch drops run the stock panhard but with wider wheels it just starts to look pretty goofy offcentered like that
07-26-2007, 12:59 AM | #7 | |
_______________ Thomas '78 Silverado '74 Monte Carlo '47 Teardrop Trailer East Texas Classics Local Club |
07-26-2007, 01:41 AM | #8 |
i think i need an adjustable panhard, how much do the run?can i get the part at an alignment shop?
07-26-2007, 04:50 AM | #9 |
weather dropping by blocks or springs in the back its plain and simple the closer you move the axel nearer to the frame rail the more the rear is kicked over off center requireing an adjustable panhard bar// the laws of physics are not suspended due to the use of dropping blocks
