Cam Brand recommendations
Hello to all. I know everybody probably has an opinion but would like to know brands that you like. I am going with a TPI setup off an 86. Currently have a 327 but trying to decide if I want to make the leap to the 383. If you want to offer specs too that is great but I thought I might call the tech lines to find what they think. I guess the TPI will make a difference?
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
as long as it is NOT From Comp Cams. the cores they use are awful and are notorious for being bad or going bad very quickly
68 short step, 406/700r4, 9" w/discs. |
go with a lunati every machine shop and racer i have talked too strongly reccomend them plus i use one myself and love it.model # 00010 duration 230@.050 lift of .480 on both intake and exhaust.i have good power from a touch over 2 grand on up over 6000 its still pullin
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
I have had tow sig erson cams that were fine. Haven't tried other brands.
69 SWB LT1/4L60E www.classicplace.com |
sig ericson...wow..are they still in business
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
Beats me...that is the only two cams I have purchased...one for my 78 firebird and the other for 67 Mustang. The last one I bought was more than 6 years ago. I think they were in orange and black boxes.
Crane Energizer for a driver. Cam and lifters can be had for $100. Good power and excellent reliability.
My vote is for Crane.
I've had nothing but good results using their cams.
"Negative people always seem to have a problem for every solution" |
creator of kong
I have used these with good results:
Crane Comp. Lunati Cam Dynamics PBM Speed Pro Summit Wolverine (who sends cores out to everyone else) I have had these to fail: 3 Comp and 1 General Kinetics |
Didnt see melling mentioned. 1500 miles on mine. So far so good.
Got over 100 thousand out of a crane blueprint 327/350 horse cam on the last rebuild.
The more I learn about women, the more I love my truck. |
Gotta Startem Early
I say step up to the 383 with the GM Vortec heads and GM's HOT Cam. Scoggin Dickey sells the heads and the entire cam kit with lifters and springs. Medium size cam, good vacuum, good idle more than 400 HP and 450 ft-lbs. Perfect for any truck.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
