Old 07-25-2007, 08:58 PM   #1
pissonNOS
senior member
pissonNOS's Avatar
control arms question
what years would have been the same as far as control arms go, Im looking to buy a used pair from the auto wreckers so im wondering what to look for there for my 69 when I called today they said they had lots. Just kinda caught me off guard I didnt think theyd be that popular
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 07-25-2007, 09:04 PM   #2
BigShoe24
True Addiction
BigShoe24's Avatar
Re: control arms question
Im not 100%, but I have a complete front end, Im not sure what shipping would cost, might not be worth it. Its in good shape, probably needs new ball joints, maybe a trip to the sandblaster. Good luck either way
BigShoe24 is offline   Reply With Quote
Old 07-25-2007, 11:18 PM   #3
st1x10
st1x10's Avatar
I believe up to atleast 81 is the same. Maybe even to 87, but I am not 100% I am sure somebody will come along that knows for sure.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 07-26-2007, 07:40 PM   #4
pissonNOS
senior member
pissonNOS's Avatar
im mainly looking for just the lower control arms, I want to cut out the spring pocket and weld in a bigger cup so i dont have to run witha cup on my bags. I seen it done in another thread and figured id give it a whirl
69 GMC bagged
Old 07-28-2007, 04:16 PM   #5
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Ok, I'm about to do the same
I have a 85 (I think) parts truck that I pulled mine off of, as far as I know the 73-87 A-arms are all the same
So how do you plan to do yours ???
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 07-28-2007, 04:51 PM   #6
pissonNOS
senior member
pissonNOS's Avatar
im trying to find an old thread of a guy that did it but no luck yet
69 GMC bagged
Old 07-28-2007, 05:35 PM   #7
pissonNOS
senior member
pissonNOS's Avatar
finally found the picture i was talking about but wasnt able to find the thread
69 GMC bagged
Old 07-28-2007, 06:01 PM   #8
culookn
culookn's Avatar
thats some clean azz work. if i could do that i would run stock arms
culookn is offline   Reply With Quote
Old 07-29-2007, 11:08 AM   #9
7deuce
Sold! 2 days after finished
7deuce's Avatar
I used an empty Oxygen bottle and cut a 4 in section then capped the bottom. It worked great then I bought the ART lowers. and stuck the old arms on a 72 blazer which has had no problems with bag wear.
7deuce is offline   Reply With Quote
Old 08-01-2007, 12:47 PM   #10
Tony@AirRideTech
Junior Member
63-87 are all the same arms....... the difference is in the bushings and the ball joints.....
Tony@AirRideTech is offline   Reply With Quote
Old 08-01-2007, 01:00 PM   #11
Kontrol Phreaks
Kontrol Phreaks's Avatar
Are you serious !!!!
- Clint -
Kontrol Phreaks is offline   Reply With Quote
Old 08-01-2007, 02:15 PM   #12
Tony@AirRideTech
Junior Member
hey there Mr Pissy Pants....... I am just answerin the fellas questions man.
Old 08-01-2007, 08:54 PM   #13
pissonNOS
senior member
pissonNOS's Avatar
hey thanks that would explain why thye dont have a shortage of them, they said 150$ for 2 of them is that in reasonable?
69 GMC bagged
Old 08-01-2007, 11:21 PM   #14
L0WRIDE
L0WRIDE's Avatar
here's another site you mite want to check www.dfwkustoms.com/forums/showthread.php?t=5702.I've don my lca the same way
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 08-02-2007, 07:47 PM   #15
Bad Karma
Magnificent bastard
Bad Karma's Avatar
If you don't have to pull them yourself, $75 each is what I was quoted at a yard in Phoenix...
So I went to the Pick-n-Pull and got one myself for 20 bucks. But it was REALLY hot outside.
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 08-03-2007, 08:08 PM   #16
pissonNOS
senior member
pissonNOS's Avatar
you gusy think I'd need to gusset this if i just weld on a lowercup?
69 GMC bagged
Old 08-06-2007, 02:55 PM   #17
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
I just finished doing my lowers for my 71. What I found is that the arm is a little taller at the bushing on the 73-up arms than it is on the 71-down. Probably wouldn't make a difference on a stock c/member but it causes interference on my sectioned on. Nothing a torch can't fix though. I used 1/4" wall 8" pipe and there's plenty of clearance with the RE7s. I didn't gusset anything but I did tack a piece of tubing on the bottom side of the arm right next to the coil pocket because it'll be thin when you cut out for your pipe. Here's a few pics, if I can help any more just let me know.
Edit: I paid 150.00 for a complete front suspension with steering and cross member that was already pulled.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 08-06-2007, 03:57 PM   #18
pissonNOS
senior member
pissonNOS's Avatar
looking good i think im gonna go pick up those control arms then.
69 GMC bagged
Old 08-07-2007, 12:01 PM   #19
evil kenny
i just bought a set of immaculate ones with shafts for $40.00
but i am the self proclaimed KING OF CHEAP
evil kenny is offline   Reply With Quote
