Old 07-25-2007, 09:33 PM   #1
wild one
Registered.........
wild one's Avatar
upper ball joint for a 1972 suburban
Hey all,
A friend of mine needs new upper ball joints for his 1972 suburban. He recently ( within the past 5K miles) rebuilt the entire front suspension with a rebuilt kit from LMC and the upper ball joints are shot! They have more play in them then the originals that he removed - which probably had 200K + miles on them.
The truck is stock height and is used as a daily driver / work truck. Now looking to use MOOG replacement parts available locally - only issue is that they are $74.00 apiece. What, if any difference is there with the 72 ball joints to the 73 + ball joint which cost half the amount? Any vendors that offer these for any less? Any suggestions or help is as always appreciated.
Thanks,
Pete
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 07-28-2007, 11:51 AM   #2
wild one
Registered.........
wild one's Avatar
Re: upper ball joint for a 1972 suburban
Anyone?
Popcorn:
Old 07-28-2007, 07:22 PM   #3
crazy longhorn
Fabricate till you "puke"
1/2 ton truck right? If you swap the spindles & outer tierod ends, you can use the 73+ upper balljoints. L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
