Old 07-25-2007, 10:37 PM   #1
ABHaulR
ABHaulR's Avatar
What do you get when you???
What do you get when you mix:
68 c10
and a
72 k5???
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
Old 07-26-2007, 06:07 AM   #2
jaros44sr
jaros44sr's Avatar
Re: What do you get when you???
Looks good, someday I want to do that to mine, Whats up with the extra gas caps?? J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-26-2007, 10:03 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Looks pretty good to me!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-26-2007, 10:29 AM   #4
Burt4x4
Burt4x4's Avatar
Sorry dood, I like the looks of a 72 better...duno why but 72 is my fave
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 07-26-2007, 12:08 PM   #5
ABHaulR
ABHaulR's Avatar
the extra gas caps were for the saddle tanks, they were placed where they cut the rocker box out on both sides. Thats a nice blazer you got Burt4x4. mines not going to be a show truck by no means, but i want to make a go dependable hunting, off-roader out of it. i like the rock sliders you put on yours. if you get a chance could you take a few pics of your mounting points.
Dwayne
Old 07-26-2007, 01:09 PM   #6
LonghornJeff
EZEKIEL 25:17
LonghornJeff's Avatar
Was the 68 a 50th?
68 CHEVELLE(HORSESHOE)
69 LONGHORN 396
70 NOVA 454(FOR SALE)
71 SWB 307
71 EL CAMINO 383
72 GMC JIMMY 350
87 BLAZER 350 WIW?
http://blog.360.yahoo.com/blog-r5CJt...9_6Orzim4L5uWM
Gun control, the theory that 110lb. women have the "right" to fistfight with 210lb. rapists.
The reason animal rights activists are more passionate about fur than leather is because it's safer to harrass rich women than bikers...
LonghornJeff is offline   Reply With Quote
Old 07-26-2007, 03:15 PM   #7
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
Whatch doing with the old front end and doors? I am Interested.
Angelse68cal is offline   Reply With Quote
Old 07-26-2007, 04:02 PM   #8
Burt4x4
Burt4x4's Avatar
Naaa show trucks are not my bag eaither
100% Function before beauty!
I do not have any pics handy on how I mounted my rocksliders. Basically my rockers were rusted REALBAD, like most. so I cut them out and that exposed the rocker box/cab support. So I cut and cleared until the 3x3square tubing fit flush against the rocker box. The bottom of the rocker box has a lip that the factory used to spot weld the rocker too. I bent the lip down and then welded the 3x3 slider to that lip. Basically my sliders are welded to the rocker boxes. I have slamed then many many times on rocks and they are still holding on strong
Good luck with your project, you will love hunting in that rig! Holds all your gear and you can set an air mattres in the back for a good nights sleep
Old 07-26-2007, 04:03 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Originally Posted by LonghornJeff View Post
Was the 68 a 50th?
That's what I was wondering
AND
I Luv my Blammy's nose job
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-26-2007, 04:59 PM   #10
ABHaulR
ABHaulR's Avatar
thats what im looking for, a good rig for everything. i've got a samurai with a 4.3 vortec, its just not big enough.
i hate to say it but, yes it was a 50th truck. i bought it for $250.00 for a parts truck. 396bb, th400, runs good. motor going into my blazer at a later time.
Dwayne
Old 07-26-2007, 05:01 PM   #11
ABHaulR
ABHaulR's Avatar
i've still got the doors, the fenders and hood, gave to a friend.
Dwayne
Old 07-26-2007, 05:07 PM   #12
RED72blazer
urban fourwheelin
RED72blazer's Avatar
I love the egg crate as well.....
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 07-27-2007, 06:25 AM   #13
vtblazer
vtblazer's Avatar
That's a great mod IMO, provides better approach visibility having the low pro hood.
Looks cool/different too.
I'd do it to my trail ride if I could ever find a front clip.
vtblazer is offline   Reply With Quote
Old 07-27-2007, 06:36 AM   #14
vtblazer
vtblazer's Avatar
What got moved where?
I thought you had just installed an early clip on your blazer, then read in another post that you used the entire cab...?
What parts from which vehicle are being used in the final truck?
Old 07-27-2007, 10:58 PM   #15
ABHaulR
ABHaulR's Avatar
vtblazer:
i used the cab along with the front clip. I cut the top off, mid section from front to back. cut the A-pillar 10" down from the top. the floor was cut just in front of the rear cab mounts, (the reinforcements in the floor). the complete dash was also used. the only thing that was used from the blazer was the bed. from the b-pillar rear-ward. the front of the bed area steps down at a 90 deg angle. i drilled the spotwelds that connected the floor to the bed. drilled the spotwelds that connected the rockers to the b-pillar, so the whole floor, rockers, kick panels, a-pillar and dash was removed as one unit. then placed on the frame of the blazer. got some measurments from the blazer floor to referrence where the truck floor needed to be bent up then drilled for spot welding. i cut the window frame 10" down on the blazer so to weld it onto the truck so the blazer top would attach. started on sat around 5:30 pm, worked sun and finished mon afternoon. was fun, had a good time.
Dwayne
Old 07-27-2007, 11:31 PM   #16
eedgell
It's the air up here
eedgell's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1185593327
Cool build! Let us know how it goes along. This is a pic that I saved. Don't knows who's it is, but I like it. 67 front though.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 07-28-2007, 12:24 AM   #17
ABHaulR
ABHaulR's Avatar
69towrig
the floor, kick panels, a-pillars were all gone. instead of trying to cut them all out and replacing them and getting them to match would have been a real chore for a non body guy. this was my first time at body work. when you took the top off, you couldn't open the doors. the body dropped about 2" then when you got the door open the body dropped even more. with the door open you could lift up on the door and lift the body about 4". dont take this as being a jerk, just working with what i have.
eedgell,
is that yours?? that is sweeeeeet.
some more info on that one....
Dwayne
Old 07-28-2007, 12:29 AM   #18
ABHaulR
ABHaulR's Avatar
eedgell, sorry i didn't read your whole post, i see its not yours. that blazer is real nice. got a lot of work to do on mine.
Dwayne
Old 07-28-2007, 05:40 AM   #19
vtblazer
vtblazer's Avatar
Originally Posted by ABHaulR View Post
vtblazer:
Dwayne
That's alot of work in only a couple days!
I've done the same thing only different...
Used a truck firewall and a blazer windshield frame to make mine.
Old 07-28-2007, 09:48 PM   #20
eedgell
eedgell's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=246510 Link
Here is a link that I hope works, to a thread I started for this topic.
Eric
Old 07-28-2007, 10:31 PM   #21
msgross
msgross's Avatar
I love it... much better IMHO
I have a "C" that i'll send ya for that hood...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-29-2007, 12:36 AM   #22
ABHaulR
ABHaulR's Avatar
thats what makes this hobby so fun. everyone has there own likes and dislikes. if we all built our trucks the same, then there would be no use for a board like this. build them, show them, be proud of them. i my not like everthing i see, but i can appreciate the time and labor that goes into everyone. you put a little bit of you into everything you do, we can all look and see something that we like about a truck, maybe not the way you would do it but turn it around and add your touch, then it looks good on yours. just keep doing the things you so i can enjoy seeing them.
Dwayne
