GM ONLY BABY!!!
What's the deal with compressor #'s?
What should I look for as for as air compressor numbers? The viair 400 puts out 2.5 cfm while the 480 only puts out 1.5cfm. What do I need to know? I'm new to this air ride thing. Also where should I install the filter/oiler? And do I need to install a check valve and where? What amp relay should I use? Thanks!!
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up Last edited by chevydog66; 07-25-2007 at 10:49 PM. |
Re: What's the deal with compressor #'s?
CFM = Cubic Feet per Minute The higher the number the faster it will fill your tanks. I do believe the 480 is up to 200 psi though. (not sure on the 400)
The Viair compressor have a built in check valve in the leader hose so that is covered. The relay should be a 40 amp I believe that is all you should need. Check out Viair.com and they have a whole run down off all their different compressor and fill rates etc.
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() |
the number is basically proportional to how big they are. The 400 does pump more air than the 480, but the 480 is 100% duty cylce at 200 psi.
Outlandish Trends - FL
I would install a water trap between the comp and the tank. This will prevent moisture/condensate from building up in the tank and getting in to your valves. Also, the stainless pigtail that comes with the comps has a built-in check valve to prevent backpressure coming back into the compressor.
-Bret 67 short-fleet sold! |
What exactly does the Duty Cycle mean? At 100% does that meant it runs more then a 50% duty cycle or????
Mike 1972 LT1/4l60e Short Bed ART Front and Rear Strong Arms http://www.67-72chevytrucks.com/vboa...50#post2151750 |
GM ONLY BABY!!!
Ya, should I get a compressor with a greater duty cycle? Does that make it more efficient?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
duty cycle is what percent of time it can run. 100% means it can run all the time, 50% means it can run half the time. What is a time? I thought it was out of an hour but it may be 10 minutes? I forgot.
Usually the higher duty cycle the less efficent as the 480 pumps less air than the 400, but the 480 also pumps a higher pressure. This probably just means the 480 has a smaller bore than the 400 which explains that it pumps higher psi and less cfm. |
"FIRESTONE COMPRESSOR AND 150PSI" Will this work for a rear airbag setup on a 72 C10?
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
