Old 07-25-2007, 11:54 PM   #1
AMD6769
6" lift ?
I installed the lift kit on the 72 blazer and the drive lines look like they will bind. Do any body know what chimes to use on a 6in lift on front and back first time ever building a 4x4 so Im learning didnot get any from rough country new spring all around. thanks jaime
AMD6769 is offline   Reply With Quote
Old 07-26-2007, 04:39 AM   #2
Re: 6" lift ?
I didn`t use any on a longbed.I think a Blazer rear could use a shim,though.
Old 07-26-2007, 07:07 AM   #3
Mudder
Mudder's Avatar
Re: 6" lift ?
I used a shim on the rear and have lowered my transfer case and I still have a vibration when I stand on it hard taking off. Not sure what it is yet. Had a shop here do new ujoints in the rear driveshaft before Norwood so gonna check out and make sure they got it back together right.
Mudder is offline   Reply With Quote
Old 07-26-2007, 07:59 AM   #4
Re: 6" lift ?
I had to lengthen my rear driveshaft.If the splines aren`t mated enough it will allow driveshaft wobble.I`m sure that`s been checked,though.
