07-26-2007, 12:07 AM | #1 |
ordered my new ORD flip shakles today
Cant wait till they get here i can throw my blocks in the trash finally.
07-26-2007, 01:38 AM | #2 |
Windy Corner of a Dirty Street
Re: ordered my new ORD flip shakles today
You won’t be disappointed.
The quickest way I found to remove the OEM rivets is to use a side grinder to cut a line down the center of the rivet then use an air hammer with the flat chisel to beat off the rivet head halves. Once the rivet heads are off, change the air hammer chisel to the center punch to beat the rivets through the frame. With grinder and air hammer it won’t take you but 10 minutes per side to remove the OEM shackle brackets. Without air tools, you will be working for a while. Since you have lift blocks now, you will probably also need to get new OEM size U-bolts as the threads of the lift U-bolts will probably not go down far enough once the lift blocks are removed.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
07-26-2007, 02:40 AM | #3 |
yeah i ordered new u bolts also. thanx for the tips all i have ia a side grinder i guess il have to grind the heads of and knock out the rivets,it wil be worth geting rid of the blocks even if it is a little extra work
07-28-2007, 10:45 AM | #4 |
i did it that way with a grinder i got one side off and i was so burnt from all the sparks i tourched the other side off and nocked the rest of the rivets out i was done in 20 mins on that side
1970 k/5 blazer--> money pit - 14bolt dana 44 350 sm465/205 36 14.50 16 tires 1972 nova plane jane 6 clyinder might sell might keep dont know 2004 chevy s-10 crewcab zr5 sold 1985 c20 chevy long bed , beater , on its way to a better place in pa from what the dmv told me 2010 kia forte koup 2.4 sx -over the river and threw the woods to the total lot it went . 1999 k1500 suburban 350 vortec 4l60e leather land yacht . |
