Old 07-26-2007, 03:39 PM   #1
Livrat
Member #1049
Livrat's Avatar
Small block AC Brackets
For Sale...
6 out of the 7 brackets for a short water pump AC setup.. Missing the horseshoe bracket that bolts to the intake manifold.
Media blasted and painted with Rustoleum Semi gloss black.
$120 shipped
Paypal preferred
Livrat is offline   Reply With Quote
Old 07-27-2007, 11:16 AM   #2
Livrat
Member #1049
Livrat's Avatar
Re: Small block AC Brackets
ttt... New price $100 shipped
Old 07-29-2007, 01:50 AM   #3
ETsC10
Hand Crafted C-10
ETsC10's Avatar
ttt to you LivRat----
...for $100, thats less than $17 a pop... blasted and painted plus they're factory parts.
Awsome!!! that's a great deal! Good Luck on your sale...
ETsC10 is offline   Reply With Quote
Old 07-29-2007, 08:43 PM   #4
billsbowtie
billsbowtie's Avatar
would you do $75.00 shipped to 24281?
i have 67/72 chevy truck parts f/s.
billsbowtie is offline   Reply With Quote
Old 07-29-2007, 08:48 PM   #5
billsbowtie
is the one in the middle far left the corect bracket ? it looks a little drifferent than my pic. in the lmc book.
Old 07-29-2007, 09:55 PM   #6
Livrat
Member #1049
Livrat's Avatar
billsbowtie.. Yes I would take $75 shipped to you..
I do believe the adjuster bracket you are asking about is correct for a small block with the stamped steel upper bracket that also had the smog pump option.. but not correct for the cast iron "horseshoe" bracket.. but can not confirm as I do not have any others to compare it to.. (it is not flat and does have two small angled bends)
Does anyone else have any info??
Old 07-29-2007, 10:17 PM   #7
billsbowtie
livrat is this the bracket you are missing?
Old 07-29-2007, 10:46 PM   #8
Livrat
Member #1049
Livrat's Avatar
Yes that is the bracket that I do not have..
I do have the long stamped steel one that also is the lower mount for a smog pump which goes in the same position on the intake manifold and runs forward to the water pump
Here is a picture of the adjuster bracket in question that is on my Burb. I can not confirm if it is correct either. It also is different that the one in the LMC catolog
Old 07-29-2007, 10:58 PM   #9
Livrat
Member #1049
Livrat's Avatar
Oopss.... I just realized after digging through my Burb pictures I do not have the front upper adjuster bracket on it.. and may need the one in the set I have offered for sale.. if you want the set for $75 I will honor it and go find another one... but if you pass I will pull the ad.
Old 07-30-2007, 11:48 AM   #10
billsbowtie
livrat you can keep the brackets it would cost quite a bit to buy just the one you need. i mostly needed the one that i ask about from intake to back of compresser. if you want you can pm me a price for the ones you don't need .i have 2 or 3 sets started . thanks bill
Old 07-31-2007, 01:25 AM   #11
Livrat
Member #1049
Livrat's Avatar
Thanks Bill,
PM sent
