Old 07-26-2007, 05:24 PM   #1
hewlett2002000
hewlett2002000's Avatar
stock master cylinder with disc brakes...
i got a question for you guys. my truck has disc front and drum back with the stock master cylinder. is this right? my front brakes stick a little bit and i figured it was a caliper problem. im just wondering.
thanks,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 07-26-2007, 05:30 PM   #2
19GMC63
19GMC63's Avatar
Re: stock master cylinder with disc brakes...
is it a dual or single reservoir?
19GMC63 is offline   Reply With Quote
Old 07-26-2007, 05:59 PM   #3
Jonboy
Slots go on anything!
You need waaaay more fluid volume to move the piston in a disc brake caliper than a drum brake cylinder. The disc master cylinders have a lot larger front reservoir to move more fluid
Old 07-27-2007, 08:24 PM   #4
hewlett2002000
its a singal reservoir. so should i put it on my list to change it?
Respect:
Old 07-28-2007, 09:27 AM   #5
Jonboy
yes, definitely.
Old 07-28-2007, 02:00 PM   #6
19GMC63
19GMC63's Avatar
yep. But you'll have to split the lines, and the front lines to the discs are smaller than the rears. You just need a dual reservoir MC with a prop valve.
Old 07-28-2007, 05:35 PM   #7
53lowdown
Junior Member
53lowdown's Avatar
I've got the same situation. Mine seems to stop ok, but I've only driven it about a block (off road) - you really have to mash on the pedal though. There's usually master cylinders and brake boosters and proportioning valves off of S10's on ebay. I'm thinking about getting one of those and seeing if it will work. Here's an example. Would this work?
http://cgi.ebay.com/ebaymotors/03-CH...spagenameZWD1V
_______________________________________
62 SWB BBW (under construction)
86 Vette Convertible
53lowdown is offline   Reply With Quote
Old 08-03-2007, 04:42 AM   #8
hewlett2002000
ok i found a dual reservoir master cylinder for a 72 chevy C10 for disc front and drum back. will this work? it looks like it will bolt strait up. its on the autozone site. Part Number: NM1494 . please let me know.
thanks,
John
Respect:
Old 08-03-2007, 09:51 AM   #9
Chevy Fleetside
Chevy Fleetside's Avatar
thanks,
John
It should work. You can use up to 87 if you want. You will need the porpotioning valve also. If you can go to the yard you can just take the valve off of a 70's chevy truck along with the front brake lines and they work just fine. I took one out of a 75 and set it in my 65 to see if the line already bent would work and it fit like it belonged there. You will need to run lines from the master to the valve. I have a tube bender and double flaring tool..
John
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
