Mounting An A/c Compressor To Headers
I Know There Is Someone Who Has A Fix For This. My A/c Compressor
Was Originally Mounted To Two Exhaust Bolts On R/h Front.(with Ramhorn Manifold) I Beefed Up My Motor And Had To Go With Headers.i Dont Know If Using Spacers And Longer Bolts Will Be Strong Enough? What Has Everyone Done In This Case?
72 2wd lwb cheyenne super youngest son.green/white 72 2wd lwb cheyenne super oldest son.green/white 71 4wd 3/4 cheyenne super frame off manderin copper / white 4 inch lift. FINALLY DONE / SOLD 72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856 |
Re: Mounting An A/c Compressor To Headers
Most of the better header mfgs make the a/c brackets to use with headers.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
I am adding vintage air right now myself. I am using ALAN GROVE bracket for the a c and going to have to modify it somewhat. The front header tube on the left side got in the way. I am cutting this bracket off using only the front header bolt and am going to weld a 90 degree piece to the head bolt holes on that side. I hope this makes sense. I have nothing bolting to that head at this time. I moved the alt. to the driver side for cleaner look.
Gary |
Licensed to Thrill!
I have an Alan Grove setup that I will sell you.
It doesn't mount on the header - so you don't have to worry about that interference. It is the 100R seen here: http://alangrovecomponents.com/S.B.Short_Pump.htm PM me if interested. It is brand new never used - still unopened hardware. DLB |
