Old 07-26-2007, 10:39 PM   #1
screamin_eagle
screamin_eagle's Avatar
vacuum advance
I'm running a holly 500cfm two barrel race carb no choke and no vacuum. witch leaves me with this one question how do I properly hook up the vacuum advance on my distributor?
screamin_eagle is offline   Reply With Quote
Old 07-26-2007, 10:51 PM   #2
jhow66
jhow66's Avatar
Re: vacuum advance
Try here:
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-26-2007, 10:58 PM   #3
screamin_eagle
Re: vacuum advance
that's where I got it along with the transmission works swell till you drop it in gear. then it looses vacuum and looses power
Old 07-26-2007, 11:02 PM   #4
jhow66
jhow66's Avatar
Re: vacuum advance
What have you got the time set at? (with vac. unhooked). How much vac. does it pull at idle?
Old 07-26-2007, 11:17 PM   #5
screamin_eagle
Re: vacuum advance
I think its a couple degrees before. so just not enough vacuum. due to it being an old crappy engine. looking at the thing its surprising that its still running at all. also their is a constant tic coming from inside. it seems to be affecting number two all but sputters on occasion
Old 07-27-2007, 12:18 AM   #6
jhow66
jhow66's Avatar
Re: vacuum advance
Time is way to low. Advance it to about 10* 10 12* with vac. disconnected from advance.
Old 07-27-2007, 12:24 AM   #7
screamin_eagle
Re: vacuum advance
rotate counter clockwise to advance?
Old 07-27-2007, 12:33 AM   #8
jhow66
jhow66's Avatar
Re: vacuum advance
Yep. Keep advancing until it starts to kick back then back off a little.
Old 07-27-2007, 02:02 AM   #9
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: vacuum advance
ive got mine set at 10*btdc
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 07-27-2007, 05:17 PM   #10
Scott68-93-97
Scott68-93-97's Avatar
Re: vacuum advance
Get a full mechanical advance distibutor
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
