07-27-2007, 09:35 AM | #1 |
C10 Club Tennessee
Thinking of running bags in the rear only
Hey guys,
Thinking of running just bags in the rear of my 2wd blazer. I have all the parts for a 4/6 drop, but was thinking this maybe a better option in the rear. Can anybody tell me what I need(parts list). No compressor or anything. Probably try to mount the tank somewhere along the frame. Thanks, I appreciate the info.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
07-27-2007, 10:14 AM | #2 |
Re: Thinking of running bags in the rear only
I am going to do the same thing and am trying to determine all the parts needed. This information came from another fellow board member
"Swapping to manual fill bags will get you where you want so why not bags? You're going to go through the effort of swapping springs anyway.... installing a couple of bags isn't much more work. From SuicideDoors site: 255c 2500# Firestone air bags @ $70ea x 2 = 140 25ft 1/4" Reinforced DOT air line @ $6 90° elbow fittings @ $5ea x 2 = 10 Schrader fittings @ $5ea x 2 = 10 Grand total for everything = $166 Price for 5" drop springs from board vendor GMC Pauls = $115 $51 difference to get that 7" drop & still tow a load..... I ran them that way for almost 3yrs before installing a tank/compressor w/controls. I've added more again. The front has bags now & I switched to Slams (I thought I would try them out). I also re-engineered a couple of things on the suspension to work a little better. As far as pics.... there's really not much to it. Bags in place of rear coils & 2 airlines running down the framerails to the bumper where I mounted the 2 schrader valves (they were installed behind my flip-up license plate)."
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
07-27-2007, 11:57 AM | #3 | |
07-27-2007, 12:27 PM | #4 |
F.A.S.T. president
I asked the question once and Scoti told me the same. Still havent done it, its too freeking hot now to work on my project, but as soon as it cools off a bit thats one of the things on the TO DO LIST.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
07-27-2007, 12:41 PM | #5 |
C10 Club Tennessee
Thanks guys, and Scoti I'd appreciate the pics.
By the way, what is the part number for the elbows and the schrader valves?
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 07-27-2007 at 12:48 PM. |
07-27-2007, 02:30 PM | #6 |
A guy with a truck
Firestone Air line service kit
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
07-27-2007, 02:42 PM | #7 |
C10 Club Tennessee
Can that be found from Suicide Doors or did you get it somewhere else?
07-27-2007, 02:56 PM | #8 | |
Sorry I didn't associate you with this information I actually have a copy of it on my desktop at work in a word file. I was trying to get out of there and head on my vacation this morning and posted it the information quick. I also thing I'm going to run a compressor. Would I need a tank for the rear if that is all I plan on bagging or should I run a tank as well?
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S Last edited by 72 Cheyenne402; 07-27-2007 at 02:57 PM. |
07-27-2007, 04:00 PM | #9 | |
A guy with a truck
07-27-2007, 08:23 PM | #10 | |
I used the schrader set-up for quite a while (2+yrs). For my limited adjustments @ that time, they worked fine..... but switching to the comp/tank made it soooooo much easier when I did want to adjust ride height. If you can spare the coin, do the tank/comp.
07-28-2007, 08:33 AM | #11 | |
07-28-2007, 11:13 AM | #12 | |
From what I understand, the Thomases generate a little less noise vs. the other brands if that's important to you.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-28-2007 at 11:14 AM. |
07-31-2007, 07:37 PM | #13 |
C10 Club Tennessee
Hey guys,
I know that the 2500 bags were recommended in an earlier post, but will the 2600 bags fit?? The reason I ask is a buddy of mine who builds hot rods and a lot of mini trucks recommended the slam specialties: http://www.*****************/SlamSpec...SinglePort.php
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 07-31-2007 at 07:41 PM. |
08-01-2007, 12:56 AM | #14 | |
A guy with a truck
08-01-2007, 01:28 AM | #15 | |
08-01-2007, 03:39 AM | #16 |
i have a couple of ?'s
1. is the 6" drop with just bags or with a notch? 2. what would be the differences between 1/2 and 3/4 ton as far as mounting and size of bags?
It's peanut butter jelly time. '74 GMC 3/4 TON 2WD LB |
08-01-2007, 05:57 PM | #17 |
C10 Club Tennessee
Hey Gringo, where did you get those RE7's I'm only seeing the RE200's on suicide doors??? If the ones that I posted a link for will work I'll get them, but want to make sure those will work.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 08-01-2007 at 05:58 PM. |
08-01-2007, 06:33 PM | #18 | |
A guy with a truck
-Chris
12-24-2007, 07:41 AM | #19 |
If I order the 7s and the airline kit mentioned above, will that cover everything or do I need some mounting adapters or something? Also, If I decide to go all-out with tank, compressor, etc. will I be able to use this setup and just add the other components? Thanks.
12-24-2007, 08:25 AM | #20 | |
A guy with a truck
