Power steering
I just finished up my power steering conversion yesterday on my 62.... Man why did i wait so long to do this... IT IS GREAT...
![]() Join Date: Oct 2006
Re: Power steering
I have been waiting to do mine on my 60. How long did it take ? Any tips ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
Junior Member
Re: Power steering
ya - me too... lookin at the system from my 80 parts truck to go on my 64.
Tips, trick, advice, photos, please? Thanks |
Re: Power steering
I used one of those conversion kits and it worked pretty good, on the 60-62 on the top right hand side thru bolt you might want to notch out the frame and add a half section of pipe to close it in, I dident and it seem's to work just fine. On the 63-66 you dont need to do that. Also what I did on the steering shaft, I cut the old rag joint off and pounded out the shaft, cut my shaft back to the appropriate length and tapered it to slide into the rag joint, then welded it around on the inside and out, also I used the front half of the rag joint off the powersteering unit. I ground the rivits off the old one to seperate it, the newer one bolts together.
I got the kit for 70.00$ and the powersteering components for 85.00$, it took me about 4 and a half hours to complete it. I think on the 63-66 it will go alot faster since the frame isnt boxed. If you have any questions I will try to answer them.... |
Re: Power steering
What kit did you use? Did you run into any problems ?
Re: Power steering
I used a REZ Engineering kit, I dident run into any major problems. Here is a link that goes into detail on what you will need to do
http://www.customclassictrucks.com/t...ring_retrofit/ |
