Old 07-27-2007, 02:19 PM   #1
I1502
Suburban/Blazer gas tank bolt-in to LB? (searched archives)
I was at the pick-part yard looking for a good rear bumper and hitch for my 3/4 LB. I now see that the Suburban frame drops at the tail, for some reason. I know, I'm just learning.
I then noticed the big center mounted tanks in the Suburbans and Blazers.
Will this bolt into my PU? I searched archives, and didn't find any solid answers, maybe I used the wrong keywords.
I actually saw a 73-87 PU go up in flames after being hit in the side. I'm not really worried about it, but if I can easily bolt in the Suburban tank, I'll do it.
thanks!
I1502: 66 GMC 3/4 LB
(new!)86 Chevrolet 3/4 LB 26,000 orig. mi., one owner.
I1502 is offline   Reply With Quote
Old 07-28-2007, 12:54 AM   #2
shadetree
shadetree's Avatar
Re: Suburban/Blazer gas tank bolt-in to LB? (searched archives)
It can be done, fabbing the gas fill hole is the hardest part, IMO. There is a FAQ on that, I'll see if I can find it.
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
Old 07-28-2007, 02:45 PM   #3
I1502
Thanks, shadetree, I'll continue looking too.
Old 08-06-2007, 11:54 PM   #4
turbo350
I'm pretty sure there are a few members here who have done this. Hopefully they will chime in.
turbo350 is offline   Reply With Quote
Old 08-07-2007, 07:04 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
This is my write-up for a SWB, LWB will have more room of course
http://www.captkaoscustoms.com/blazertank.html
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-07-2007, 08:07 PM   #6
Russell
Professional Grade
Russell's Avatar
I have a Suburban tank installed on my 3/4 ton 4x4, as mentioned by shadetree, the filler-neck has proven to be a big challenge... My fuel lines are hooked up, and the truck runs off the fuel in the tank, but I currently have no way of filling the tank back up =/
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
