Old 07-28-2007, 09:59 AM   #1
xshadow
undercoating
What would work better on the chassis? I was going to take a wire brush and clean it up a bit. I was thinking about either spraying it with rustolum primer and then paint it black. I can get it in quarts and spray it, or I could use spray cans of undercoating. I’ve been looking in local stores and don’t see too many options. The other option is a friend of mine says he took some tar and thinned it and brushed it on. He claims that it dried without being tacky. I’ll have to look at it. He has more that he will give me. According to him it looks as if it was painted flat black. With going over something that still has some rust on it What do you guys think would hold up best. I don't think i'll get the chassis to bare metal with a wire brush. Keep in mind I’m working on a limited budget and would like to pick something up locally.
xshadow is offline   Reply With Quote
Old 07-28-2007, 11:17 AM   #2
Joe67
67 is sold
Re: undercoating
Paint/sealer before undercoating material every time.
Undercoating blocks drain passageways causing rust over time.
Just keep the underside clean and it will be good to go
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 07-28-2007, 11:33 AM   #3
cdowns
cdowns's Avatar
Re: undercoating
rustoleum is fine for an inexpensive clean up of the frame and in the future its easier to strip off and redo if you want to go with a higher end finish
Old 07-29-2007, 12:01 PM   #4
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Re: undercoating
I like Zero Rust as a product. It works with rust. You do not have to top coat as it is already black but you can. I did my frame in this and top coated it in a black paint of my choice. Too often you end up buring rust by undercoating a frame!
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
