Old 07-28-2007, 10:53 AM   #1
Rally Nova
Rally Nova's Avatar
Replacing GMC cabs
I need some expert opinions! My 1969 GMC has some rust issues in the firewall, kick panels & above the windshield. I bought a 1968 GMC cab that is much better condition in those areas & plan to get this one repaired & painted before swapping cabs. My questions are should I keep the '68 hand brake lever or modify the cab for the foot pedal parking brake? I like the look of the '68 hood more than my squared off '69 & need some advice on what has to changed to get a '68 GMC hood to fit a 1969 GMC front end. If it takes a lot of changing, we will probably cut & modify a 69-72 hood to give it more layback. My last question is about the chrome trim on the back of the cab, below the back window. How do I put the trim on a cab that didn't have it originally? I plan to get it painted red & white, since the '68 cab is original red. TIA!
1969 GMC C-1500
1972 Rally Nova
1988 Monte Carlo SS
2004 GMC 2500 Crew Cab
Rally Nova is offline   Reply With Quote
Old 07-28-2007, 11:17 AM   #2
truckdude239
truckdude239's Avatar
Re: Replacing GMC cabs
the68 hood will not fit unless you change the whole front end
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 07-28-2007, 01:56 PM   #3
john
member #16
john's Avatar
On the hood you only need to change the top bar on the grille to a 67-68 bar and im pretty sure the hood latch has to change. The GMC fenders are the same between 68 and 69.
john is offline   Reply With Quote
Old 07-28-2007, 02:15 PM   #4
Green Machine
Green Machine's Avatar
Personally I like the 68 hand brake better than the 69 up foot brake, we have both styles and on manual trans trucks so they get used a lot.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 07-28-2007, 02:39 PM   #5
BurnoutNova
BurnoutNova's Avatar
it will not be a direct bolt on, but it can and has been done
BurnoutNova is offline   Reply With Quote
Old 08-01-2007, 08:37 PM   #6
Rally Nova
Rally Nova's Avatar
Ttt
1969 GMC C-1500
1972 Rally Nova
1988 Monte Carlo SS
