drag shocks ?
.....since they dont make drag shocks for our trucks anybody know what front car shock would interchange with 67-72 1/2 ton?
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
Slowly getting CRSS...
i think they do check with MotherTruckers or over in the Suspension forum i saw a post over there where i believe he said he had em.
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
i rather not go with coil overs...... usually pretty pricey..couldnt find them on there site though...wanted to go with the cheapo 90/10 thought maybe someone knew what car would be the same...thanks anyhow
Half a bubble off!
Just post a pic of that beautiful Angel, we'll tell you anything you want to know, really! Promise! Really!
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
oh no....... first the answer........ then the pic......cause once i post a pic of angel then everybody forgets about my shock question......lol
Measure your shock with all the weight on it then jack it up at the crossmember till the wheels are off the ground and measure the extended shock and e-mail the measurements to me and i'll match you up, we have 90/10-80/20 and 60/40 for the front and 70/30-60/40 and 50/50 for the rear in a decent priced shock besides the coilovers.
Rest in Peace Ed. Thanks for all the good times. |
the measurements are 12 3/8" and 14 1/4" most gm cars have a stud at the top instead of a bolt someone once said they thought some mopar would work......ill be looking for 90/10 fronts ......looked on your site but did not see any shocks at all...you hiding them?......lol...thanks for checking for me...
oops you said e-mail them to ya doing that now
....ok anybody else? how about just the name of a car with eye bolt to eye bolt shocks in the front,
Try checkin on Doetch Tech's, they offer an adjustable shock, It is a stock mount clicker-shock, adjusts from 50/50 to 40/60 and so on.
they have a website? searched it ,,but came up empty
The Mighty Blue Bottle
can't help but sure would like to see just what you come up with
good luck
1967 Chevy C 10 Custom 350 780 cfm 467 lift 278 dur ported&pollished 2400 stall 350TH B&M shifter 175 shot of nitrious |
#13 |
I know of only one carrier in my area. Day Motorsports in Texas, they carry the product line, your application may be a little out of their ordinary routine, but I bet they will find it for you. Day has great prices on DoetchTech Shocks.
Member of the "Old Farts Club" |
#14 |
The information I e-mailed you is from COMPETITION ENGINEERING, 3 way adjustable. No 90/10 only 70/30 in that length and style. The only 2 options is to get top stud shocks and screw a HEIM or sphericle rod end to it to get the top eye OR take the shock stud out of the frame and weld/bolt a gusseted perch (looks like your core and cab frame perches) to the frame. Then any top stud / lower eye shock will work.
#15 |
thanks mothertruckers i like the heim joint idea...i think that would work great
