Old 07-28-2007, 12:41 PM   #1
pound41
Floor Pan Install Question
The front floor pan patch panel is longer and extends past the factory seam. Do you cut the panel and bend a lip to meet the cowl lip( where they were spot welded together) Or have folks just butt welded it at the seam. Advice and Pics needed!
pound41 is offline   Reply With Quote
Old 07-29-2007, 07:59 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Floor Pan Install Question
I cut and bent a flange on mine, makes it more like the original. You could butt weld it also, it's your choice....
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-29-2007, 08:08 PM   #3
pound41
I want to cut and bend a flange just want to be accurate with my cut and bend
Old 07-30-2007, 06:11 AM   #4
jaros44sr
jaros44sr's Avatar
Put your floor patch on top of the cowl floor and draw a line. Measure from that line to the flange, what ever that demension is add a 1/2" for the flange and that is how much you have to take off the floor board patch panel.
If your unsure, you can do a test pc. of about 3" to check to see if it comes out rite.
You can refer to my thread as I think its in there, but I don't know how to attach it..... J.
SAFETY FIRST
AS usual, off topic
Jim
