Old 07-28-2007, 01:44 PM   #1
scotty101
Gm 363?
We have recently pulled a 363 engine out of an old straight truck and i was wonderin if this engine is worth anything or should it just be scrapped? it has a holley carb on it. Just wondering thanks
scotty101 is offline   Reply With Quote
Old 07-28-2007, 03:32 PM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: Gm 363?
Ive never heard of a 363? What is it?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 07-28-2007, 05:04 PM   #3
C&C Chevy
C&C Chevy's Avatar
Re: Gm 363?
http://www.73-87.com/7387info/engineid.htm
This might help ID the engine better..
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 07-28-2007, 06:09 PM   #4
Yankeelights
Yankeelights's Avatar
Re: Gm 363?
Got any PICs of this engine?
Yankeelights is offline   Reply With Quote
Old 07-29-2007, 08:49 AM   #5
scotty101
Re: Gm 363?
I will try get some up today or tomorrow.
Old 07-29-2007, 09:19 AM   #6
ont_guy_38
ont_guy_38's Avatar
Re: Gm 363?
They were 366 cubic inches and is it worth anything?.Probably not to the average person but you never know till you advertise it for sale
ont_guy_38 is offline   Reply With Quote
Old 07-29-2007, 10:32 AM   #7
ChaseDale3and8
ChaseDale3and8's Avatar
Re: Gm 363?
Those were a big block that were used in the C-60 dump trucks and in school buses I believe. I don't think that they are really worth a whole lot but somebody out there might want it so I'd advertise it for sale and see if anybody wants it before I'd scrap it. ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 07-29-2007, 03:18 PM   #8
scotty101
Re: Gm 363?
yeah it is a 366 not a 363 sorry for the confusion i ment to ask along time ago but never got around to it and now i had a mental lasps on the last number. but that is what i was wondering. thanks and this engine came out of a old feed truck. so what about a holley carb off of it do they fit on a 350? of 305 or are they different bolt patterns? here are some pics
Old 07-29-2007, 03:47 PM   #9
MylilBowTie
Right turn Clyde
Re: Gm 363?
The carb will bolt up. Depending on what type of intake you have you may need an adapter. The distributor, air cleaner assy, alternator will also work. May have to remove the pulley on the alternator if you don't have a serpentine pulley setup. Some of the later 85-87? years had a serpentine and v-belt.
Old 07-29-2007, 04:40 PM   #10
Pyrotechnic
Pyrotechnic's Avatar
Re: Gm 363?
Thats a Target Master so it's obviously been rebuilt.
The 366 was a tall deck, small bore big block. It's bigger brother, the 427T was a 427 with a tall deck, which made it popular with racers because you could get larger displacements without paying big bucks for a tall deck aftermarket block. The 366 isn't really valued though because the bore is too small for performance purposes. The bore is smaller than that or a small block 350.
It IS a very strong motor though. The pistons have an extra ring for durability because they were designed for the C60 medium duty trucks. It's a very low revving motor. The valves float at around 4000 RPM. Tons of torque though
If you got it and it's a good running motor with lots of life left, I say run it. It'll be perfect for pushing a highway gears like 3.08's down the road since it's got so much torque. Would be good for towing too. If it's a low miles motor, then it's going to last you a LONG time.
Pyrotechnic is offline   Reply With Quote
Old 07-29-2007, 04:57 PM   #11
scotty101
Re: Gm 363?
would a double stack air filter like that fit on a 350 or is that a pointess swap? vs. the stock air intake. thanks for the info on it, it is very intrestin and helpful i dont know alot about engines yet so i am trying to learn as much as i can
Old 07-29-2007, 08:57 PM   #12
scotto0609
Junior Member
Re: Gm 363?
I have a 366 in my dually and it runs nice. Nice low end torque but runs outta steam after 3500 rpm. It ctually runs so nice that I dont want to take it out and fix the rear main seal,so I constantly put oil in it!
scotto0609 is offline   Reply With Quote
Old 07-29-2007, 09:13 PM   #13
liljon285
That Guy
liljon285's Avatar
Re: Gm 363?
So is it diesel or gas...if its gas then its a bbc right? I wouldnt mind building one...get a lot of unique rep. out of it!
1978 Chevy Scottdale Stepside, 3rd engine- 350c.i. built with cam and lifters, holley 670cfm carb. and intake,heads shaved .60. Truck is a project, and I am its restorererer!
liljon285 is offline   Reply With Quote
Old 07-29-2007, 09:28 PM   #14
78chev
78chev's Avatar
Re: Gm 363?
Distributer means gas, right?
78chev is offline   Reply With Quote
Old 07-29-2007, 09:40 PM   #15
dswancutt
Re: Gm 363?
Sounds like you live in farm country, so if it is a good running motor and doesn't use oil, should be easy to get rid of as there are a lot of Chevy and GMC trucks that are used as farm truck. Just need to advertise it where farmers and such can see it if you want to get rid of it.
dswancutt is offline   Reply With Quote
Old 07-29-2007, 09:43 PM   #16
liljon285
That Guy
liljon285's Avatar
Re: Gm 363?
Oh wow it was right there lol im blind! So is it considered a big block or small?
Old 07-29-2007, 09:55 PM   #17
liljon285
That Guy
liljon285's Avatar
Re: Gm 363?
oh OK it is a big block wow thats small...i would like to buy it and build it but !. i dont have the money lol and @. from eerybodys comments it dont think thats the best thing to do...and plus where do u find the parts for it!?
Old 07-29-2007, 10:04 PM   #18
78chev
78chev's Avatar
Re: Gm 363?
Hey, was'nt tryin to be mean. I was a little confused too b/c long stroke & small bore (relatively) usually means diesel.
Old 07-29-2007, 10:29 PM   #19
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: Gm 363?
ya its gas and i think it kinda cool ive never heard of one
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 07-30-2007, 09:54 PM   #20
longhorn71
longhorn71's Avatar
Re: Gm 363?
the Crank in all the big block are the same as well
longhorn71 is offline   Reply With Quote
Old 07-30-2007, 10:00 PM   #21
Yankeelights
Re: Gm 363?
Kool engine ... if I had it I'd have to drop it into something.
