Old 07-28-2007, 06:46 PM   #1
boot85
71 Chevy
4x4 conversion
What all would I need to do to convert a c20 to a K20 if I had a donor truck and didn't want to use the frame or body from the donor. I tried to search the archives but couldn't find any, I know there has to be a couple out there.
71 C10
72 C20
62 Chevy II 2DR HT
boot85 is offline   Reply With Quote
Old 07-28-2007, 06:49 PM   #2
boot85
71 Chevy
Re: 4x4 conversion
I am thinking that I would need to use the crossmembers and the leaf spring hangers to get the 2wd frame converted to a 4wd frame. I am wondering if all of those will just bot up to existing holes on the 2wd frame. Would like to know what is ahead of me if I would try this.
71 C10
72 C20
62 Chevy II 2DR HT
Old 07-29-2007, 12:08 AM   #3
1969k10stepside
Re: 4x4 conversion
If you have the donor 67-72 4wd chassis,use your body on that chassis.That's the easiest way.If not,take all of the spring hangers,springs front and back,shackle mounts,transfer case crossmember and torque mount and the engine crossmember,and both driveshafts,etc.The 4wd trucks had the motor sit back more in the chassis so its not all the same.If you dont move the motor to the 4wd spot,there is differential to motor clearance issues.Keep in mind the frame rises more up front on a 4wd too.Bolt in swap?No.Conversion for a beginner?No.But it can be done.The easiest way is to use the 4wd chassis on the 2wd body though.You can probably get the rolling chassis cheap as to buying all the parts individually.Keep in mind you still have to get a 4wd style tranny and transfer case.
1969k10stepside is offline   Reply With Quote
Old 07-29-2007, 01:42 AM   #4
Mudder
Mudder's Avatar
Re: 4x4 conversion
Moved to 4x4 where the info can be found.
Mudder is offline   Reply With Quote
Old 07-30-2007, 12:49 AM   #5
GMCMAX
Active Member
GMCMAX's Avatar
Re: 4x4 conversion
Check this maybe: http://67-72chevytrucks.com/vboard/s...d.php?t=188520
done it, lots of changeover even with a donor, learned a few things about differences in frames....... IIRC the rear frame on coil rears is different from leaf
frames, need high hump cab or cab lift to clear tcase...........
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 07-31-2007, 06:32 PM   #6
ABHaulR
ABHaulR's Avatar
Re: 4x4 conversion
its not that bad a job. i convrted mine but used a 88 sub for the parts truck. paid 800.00 for the sub. whent in halfs with a friend, he took the motor i got the rest. had to convert the master cyl for disks. mine was c20 with coils and now its a k20 with coils... . rides good but has alot of body lean in turnning. will soon convert over to springs. you'll have to get a 4x4 engine cross member, fab your own or purchase an after market one. the axle will not clear the 2wd crossmember. you have to change the steering box. unless you decied to go cross over. get drive lines made, thats all i can think off right now. hope this helps.
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
Old 08-04-2007, 06:14 PM   #7
jake60
Re: 4x4 conversion
It's not necessary to move the engine back for additional engine to differential clearance but it is real tight. You might want to consider splitting the difference between the stock 2x engine location and the 4x4 location.
Rear leaf spring hangers will work w/o mods on a 2x frame.
It's really not a difficult mod.
"Common sense is very uncommon" Rudyard Kipling
jake60 is offline   Reply With Quote
