Old 07-29-2007, 02:24 PM   #1
beaterC10
Replacing core support and inner fenders
I need to replace my rusty inner fenders and I want to install a dual headlight core support on my 86 GMC while I am replacing the inners fenders. I will most likely have to do this solo, so I was wondering if this can be done with the outer fenders and hood still installed on the truck.
Anyone replaced inner fenders or a core support with the clip installed on the truck?
beaterC10 is offline   Reply With Quote
Old 07-29-2007, 02:30 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: Replacing core support and inner fenders
take to hood off but the fenders will be fine. (removing hood is a safty thing really i mean it a chunk of steel ove rur head) If done this before and it not hard, i to did it solo. but to do the dual head light set up you will need the wiring harness as well as anythink that is dual head light set up.
And just for reference here a picture od mine
and hees my custom grille i made for it but never istalled all the way
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 07-29-2007, 03:11 PM   #3
rfmaster
rfmaster's Avatar
'C10
I replaced inner fenders on my '75 without removing hood or any other main body parts. 86 may be different. Just be aware that you may need replacement body bolts and U-nuts that clip to the fender inner lip. Make sure that contact area between inner fender and other parts is clean. Use body filler RTV to make sure that moisture does not get into nook and crannies.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 07-29-2007, 06:45 PM   #4
Srubydo1986
The Crazy Machanic
Originally Posted by rfmaster View Post
'C10
//RF
hey thats a good idea might have to do that next time. all i did was clean every thing reall good then undercoated everything to never allow rust to start. THe cool thing it hasnt yet (knock on wood)
newest additions
Old 07-29-2007, 07:38 PM   #5
Jonboy
Slots go on anything!
Dave, it can be done. Use a board or something to hold the hood up. The core support will slide up into place. You might have to move a little wiring around, but it's nothing major.
Old 07-29-2007, 07:55 PM   #6
beaterC10
Thanks for the suggestions.
