Oil filler tube question?
Just curious about the oil filler tube.....should my '72 350 have one? It just has a fill cap on each valve cover.
Thanks!
Grant |
Re: Oil filler tube question?
They came on the a/c trucks. So if yours was a stock a/c truck then yes. If you have heat only then no.
Thanks Aaron! Yes I do have factory a/c. Would it matter if it has a power brake booster or not? My truck has manual brakes.
Thanks again!
Grant |
It shouldnt matter. The reason you should have the tube is that the oil fill plug is towards the front on the passenger cover and towards the back on the driver side. With the compressor mounted, it covers the front oil fill plug on the passenger side. So you have to use the driver fill plug. So they put the tube in the rear filler on the driver side to make it easier to fill. If you can fill it as is with no problem dont wory about it. But if you would like it check the parts board they pop up every so often. Good luck.
Interesting thread. I have never ever seen a filler tube on a 72. I have seen plenty on 69 and earlier but not any 72's. I would like to know for sure myself.
72 Cheyenne Super 80 Silverado Blazer 2wd |
SWB 4X4 CLUB
Check mout the third post in this thread. Its a 72 and it has one. Not sure if its original to the truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=251790 Jason |
~Rest In Peace~
i guess it beats taking out the distb. to fill it up
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
![]() Join Date: Nov 2006
My 72 With Air Has One.
Bob
I BELIEVE IN JOHN 3:16 |
My 72 with AC has one too.
1990 Chevy Silverado (My DD) 1978 Chevy Bonanza LWB (My LWB to SWB 1 day project) 2015 Hyundai Sonata (Wife's DD) |
fwiw - my 72 has heat only and no fill tube
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Most of them end up disappearing during an engine overhaul or when the a/c is disconnected. Which is why alot go missing. I know cause when I bought the green and white the kid lost it along with the a/c brackets.
And here is how it works out: with a/c= oil filler tube heat only= no filler tube. Last edited by Aarons72s; 07-30-2007 at 10:40 PM. |
![]() Join Date: Jul 2004
Our 71 C20 has one, no air but has power disks of course.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#13 |
Well, thanks to this great site full of knowledgeable folks and another fellow board member with parts for sale, I have an original filler tube on the way. There's no doubt that I'll be spending lots of time here, asking more questions and learning more about these great trucks!
Thanks!
Grant |
