07-30-2007, 09:59 AM | #1 |
Question about brakes.
It looks like I need a new brake booster (leaking fluid out of it). I still have drums on the front, but I will be changing to disc in the future.
My question: is there anything I should do now in preparation for the disc swap that will still work for the drums? I guess what I'm trying to say is, I don't want to do anything now that I will only have to undo when I do the swap. Keep in mind, it'll be a little while before I do the swap because other things are higher on the list of priorities. The trucks been parked for a while and I just want to make it safe for now; so far on the agenda is booster, wheel cylinders and bleeding. Master cylinder and shoes appear to be ok; anything else I should consider? Thanks in advance. Ronnie
1968 C10 Stepside 396 bored .030 TH400 |
07-30-2007, 10:22 AM | #2 |
Active Member
Re: Question about brakes.
replacing the wheel cylinders can really be a pain. if you are going to disc anyway, are you sure you need to replace them?
07-30-2007, 11:53 AM | #3 |
Long Fleet Club
What kind of booster is it? Hydraulic or vacuum
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
07-30-2007, 12:02 PM | #4 |
if you're leaking brake fluid you've got a bad master cylinder// if its engine oil leaking out the booster you've got a problem with the way it's hooked up to the manifold
07-30-2007, 12:06 PM | #5 |
Long Fleet Club
and if it is a hydraulic booster then it is a bad booster
07-30-2007, 01:43 PM | #6 |
<a href="http://picasaweb.google.com/rophle/Truck/photo?authkey=2Y3xTzf9-Ic#5093047276457201474"><img src="http://lh6.google.com/rophle/Rq4jg4mAj0I/AAAAAAAAAAs/qFOyIDqb4d0/s144/Engine-Bay.jpg" /></a>
hopefully the pic works (I'm not too good at posting pics), figured it'd be easier to show you.
07-30-2007, 01:43 PM | #7 |
Crap it didn't work, any ideas on how to post a picture? I'm full of questions.
07-30-2007, 01:44 PM | #8 |
http://picasaweb.google.com/rophle/T...47276457201474
If you click the link, it'll show a pic of the booster, hope this helps.
1968 C10 Stepside 396 bored .030 TH400 Last edited by rophle1; 07-30-2007 at 01:46 PM. |
07-30-2007, 02:10 PM | #9 |
Long Fleet Club
here it is but smaller then your link
07-30-2007, 02:24 PM | #10 |
hope your better at doing mechanical stuff than youse are at posting pics
07-30-2007, 02:31 PM | #11 |
~Rest In Peace~
i see rust straight below the master cylinder your booster is vacumm
to make sure its working right pump up the brake pedal and hold then start the truck up if the pedal drops towards the floor then its work fine if you cant get the pedal to hold then check for leaks at the wheel cylinders and master cyl. and check your brake lines (rubber) a collaspe line could cause problems
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
07-30-2007, 02:36 PM | #12 |
Long Fleet Club
the rust would be from the master cylinder leaking
07-30-2007, 02:54 PM | #13 | |
Thanks for the info guys. The biggest problem is when I press it to the floor, it just stops really slow, they don't seem to grab quiet as good as they did before it was parked. I noticed the leak around the booster, so that's why I assumed it needed to be replaced. Would the cylinders be the problem with slow stopping?
07-30-2007, 02:58 PM | #14 |
~Rest In Peace~
maybe a an old master cylinder this one look dry just rusty from the old fluid
07-30-2007, 03:07 PM | #15 |
Long Fleet Club
If your master cylinder is leaking it would allow some pressure bleed off through the back and make you have to push the pedal farther to get the wheel cylinders to apply the brakes. You would see the rust on the booster coming from the back of the cylinder.
