Old 07-30-2007, 04:11 PM   #1
Jcentsr6
Junior Member
Jcentsr6's Avatar
One more question for the smart guys
I am at the point to purchase a full disc brake set-up and wheels.
Q1: Will disc brakes change the wheel fitment from drums. Offset I
mean.
The reason I ask...I have a 6 lug set-up now. Thinking of swaping everthng to a 5 lug set-up...but I need to have the wheels here at the same time as brakes get installed to drive out of the shop. I dont have a place to install new brakes and measure everything to order wheels...and let truck sit.
If I measure my 6 lug drums for offset and order wheels based off those measurement (offset) will everything fit.??
I think that it would be within 1/2 an inch of offset....I am installing 18" front and 20" rear so brake clearance should not be an issue.
going to sell this one...looking for a SWB project next.
Jcentsr6 is offline   Reply With Quote
Old 07-30-2007, 04:23 PM   #2
powell72
powell72's Avatar
Re: One more question for the smart guys
Disc brakes increase the front track width from drum brakes. I would find some real cheap steel rollers or see if you can borrow a set of wheels to get you out of the shop until you figure out your width and backspacing for the new wheels.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 07-30-2007, 04:38 PM   #3
SCOTI
SCOTI's Avatar
Drum to disc conversions increase track width about 3/8" per side.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
