Old 07-30-2007, 05:05 PM   #1
vern350
like a rock
vern350's Avatar
identify me - series number 2
what would this mechanism in the rear of 87 1/2 ton 4x4 be. Thanks again
vern350 is offline   Reply With Quote
Old 07-30-2007, 05:08 PM   #2
Blazer1970
Blazer1970's Avatar
Re: identify me - series number 2
That is an Eaton Automatic Locker, often referred to as a "Gov-lock". When one wheel spins those flyweights in the center of the picture spread out and apply clutches to lock the axle shafts together.
Blazer1970 is offline   Reply With Quote
Old 07-30-2007, 05:16 PM   #3
1969k10stepside
A.K.A.-The Gov Bomb...
1969k10stepside is offline   Reply With Quote
Old 07-30-2007, 05:33 PM   #4
vern350
like a rock
vern350's Avatar
i've recently got 2 trucks. One is pictured, Gov-locked with 3.42 gears in a 10 bolt. The other is open with 3.07 gears in a 12 bolt and a d44. Which is better to keep. Thanks for the quick replies.
Old 07-30-2007, 06:08 PM   #5
msgross
msgross's Avatar
depends, are you dying for the ratio or a locking rear? I haven't heard good things about that rear but I have never had one either.
10 bolt vs dana 44 is pretty equal so which set seems to be in better shape?
Do you have large tires? If so then a larger ratio than either of these would be better IMHO...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-30-2007, 06:47 PM   #6
vern350
like a rock
vern350's Avatar
35" bfg mud terrans. Both are in good shape. I would like to sell a set, just gotta figure out what set to sell.
Old 07-31-2007, 06:35 AM   #7
Blazer1970
Blazer1970's Avatar
Keep the 12 bolt. You will kill that 10 bolt/gov-lock fast with 35s. Even the 12 bolt is marginal for those tires. You also should have 4.10 gears or lower with 35s.
Old 07-31-2007, 03:46 PM   #8
68K20 x Drill
The Gov-lock works well if you are gentle with it, and if you aren't, you should probably get a 14 bolt anyway. It should work with a steeper gearset.
If you only plan to use the truck for wheeling, get rid of that thing.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 07-31-2007, 04:04 PM   #9
vern350
like a rock
vern350's Avatar
truck is going to be pulling trees and will be wheeled. Truck will never see the road. I have a 14 bolt. Its 8 lug and would like to use the d44 front diff which is 6 lug, so i guess i'll be using the 12 bolt and d44 for now. Another quick question..... which is stronger, 3/4 ton 10 bolt or a d44 from a 1/2 ton?
Old 07-31-2007, 05:21 PM   #10
Blazer1970
Blazer1970's Avatar
They are basically the same strength. The 3/4 ton axle has bigger rotors for slightly better braking.
I would STRONGLY recommend that you go 8 lug right now. Use the 14 bolt - it probably has 4.10 gears already. Convert the front 44 to 8 lug if you want to use it. Unless you already have the 6 lug wheels and tires you would be foolish to use the 6 lug stuff.
Old 07-31-2007, 09:43 PM   #11
vern350
like a rock
vern350's Avatar
i have got a 3.73 rear that is 14 bolt. I have got 6 lug mags that have 15" bfgs mounted on them. So i would like to stay 6 lug. I guess i go until i break something and go from there.
