07-30-2007, 06:28 PM | #1 |
What is biggest size tire I can fit under my pickup?
I have a 1970 Chevrolet C-10 pickup that I am restoring. I want to go for the Pro Street look with the big rear tires,both for maximum traction and good looks, and skinny front tires. I plan on lowering the truck about 2 inches as well. I want to get the biggest tires in the rear,in diameter and width, as possible without them rubbing or interfering with other components or without resorting to a narrowed rear end or tubs. I will probably just go with 15" wheels BTW. What's the biggest I can go? Also what kind of backspacing will I need? Is there a chart on the internet where I can look up tire sizes for particular vehicles?
07-30-2007, 07:34 PM | #2 |
Re: What is biggest size tire I can fit under my pickup?
It Depends On How Wide Your Wheels Are, Backspacing, Ect. I've Got 15x8.5 Wheels And Have Had 255/70/15 Eagle Gt II Tires On It. I Had A TON Of Room Left Up Front. If Your Gonna Go Pro-Tour I'd Suggest A-Arm Upgrades ( Tube ) And A Spring Change First Off. A Little More Money Spent But A World Of Difference As Far As Ride And Grip. As Far As Tires.... Couldn't Tell You. From Personal Experience, I'm Enjoying My New Toyo Proxes ST's. They Are 275/60/15. They Will Help As Far As Sidewall Flex And Wet Traction. Out Back, I'd Do Springs, A New Panhard Bar ( Assuming You Have Trailing Arms. ) , And Sway Bar. Early Classic Has All Of That Stuff. Good Luck, Man. Let Us Know What Happens.
07-30-2007, 08:00 PM | #3 |
72 Chevelle Club
I have 15x11 with 5 1/4 backspacing 275 60 15 bfg with no clearance issues
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
07-30-2007, 10:19 PM | #4 |
Spanked once
bump,
07-30-2007, 10:30 PM | #5 | |
As far as tires go, I've been looking at either the M/T Sportmans or ET Drag Radials. ET Drag Radials come up to about 29" so I fairly sure they'll fit no problem. But I would like the tire to fill up the wheelwell as much as possible. |
07-30-2007, 10:55 PM | #6 |
72 Chevelle Club
Here's another truck I built 15 x 10 slots with 31x10.5x15 with 4''back space wheel lowered about 4'' no clearance issues.
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker Last edited by Bob 68327; 07-30-2007 at 10:55 PM. |
07-30-2007, 11:31 PM | #7 |
i got 15X10's with 295/50's, not sure of back spacing but their American racing outlaw 2
Justin 1970 c/10 short wide bed WTT 1970 chevy front end for 67/68 chevy front end WTT 2 15x10 american racing outlaw 2 wheels for 2 of the same in a 15x7 or 15x8
07-30-2007, 11:56 PM | #8 |
Official Site Guitar Shredder
in the rea i run a 335x55-17, i will check back spacing for you, my rear rim is 12 inches wide and although it is very close to the inner wheel tub.qbout 1/2 inch. ive never had any rubbing problems, unless i got on it hard from a dead stop. with a posi unit. it tends to get a little sideways from time to time
07-31-2007, 11:35 AM | #9 |
When I get the truck drivable,I'll see if the local tire guy,whom I know well and have done a lot of business with, will let me use some extra tires he's got laying around to see what will fit and what won't.
07-31-2007, 11:52 AM | #10 |
These Trucks Can Run Some Big Tires With Not Much Of A Fuss. Stepsides Are Able To Handle About Anything You Can Throw At Them. BTW, Are You Lowering The Truck? Cause If So, That Throws A Few More Wrenches Into The Works. As Long As You Don't Go Crazy With The Drop, You Can Run Whatever.A 2/4 Drop Is Good, But Anything Lower You Run Into Front Clearance Problems.
08-01-2007, 11:14 AM | #11 | |
08-01-2007, 11:22 AM | #12 |
Yeah, I Could See That Spare Tire Hump Being A Problem. You Could Move The Spare Under The Bed, Unless You're Going To Put The Gas Tank There. Then I Guess You'll Have To Go Commando, So To Speak.Worse Case Is A New Wheel Housing On That Side Of The Truck. I've Never Liked The Idea Of That Spare Tire Holder On The Side Of The Bed.Too Easy For " People " To Gank Your Spare.American Racing Has A Program That Shows Their Wheels On Your Truck. That Might Help.
08-02-2007, 12:32 AM | #13 | |
08-02-2007, 09:40 AM | #14 |
I have 275x60x15 on all fours and I am have a slight rubbing issue on the fronts. I have a 2-4" drop. Truck is a 70LWB. The wheels are 15x8 5 lug truck ralley's. I think I will drop to a 225x15x60 up front so I get away from the rubbing issues. I too thought I would have plenty of room up front but not so.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
08-02-2007, 12:01 PM | #15 | |
08-02-2007, 01:13 PM | #16 |
Thanks Big White GMC on your recommendation. After reading your suggestion I think you are right. I will go as large as possible w/o rubbing. Thanks again!!!
08-02-2007, 11:07 PM | #17 |
No Prob, Bro. I Think These Trucks Look Soooooo Good With Some Big Meats In The Fenders. A 265 Might Be As Big As You Can Go Up Front With That 2'' Drop. Is The Drop Done With Springs Or Spindles ?
08-03-2007, 12:41 AM | #18 |
Spindles...
08-03-2007, 07:09 AM | #19 |
Green club
I am runing a 285/70/15 in the wheelwells of my fleetside, I am not sure how these would look in a step bed though?
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
08-03-2007, 07:13 AM | #20 |
67-72 Addict!
67shortie your truck looks slick! I run 275/60/15 on all 4 corners with no rubbing dropped 2.5" in front.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
08-03-2007, 09:52 AM | #21 |
I would also suggest the 285/70/15 rear with a 235/70/15 front for a prostreet look. If you want good traction, look at some of the drag radials. I think Mickey Thompson makes a 295/60/15, which is about 29.5" tall. I've seen 6" rear drops without clearance issues with these tall tires.
08-03-2007, 09:53 AM | #22 |
I have 15x10 all around. Front tires are 255 60 15 and the rears are 275 60 15's. No rubbing issues. The truck was already lowered when I got it but it's not lowered much. Not sure exactly how much.
08-03-2007, 04:24 PM | #23 |
295/65/15 MT drag radials. 3/4 drop. No problems...
08-03-2007, 04:32 PM | #24 |
Does this look like model or a miniature truck? The way it's photographed it looks fake. Cool, but fake
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
08-03-2007, 04:42 PM | #25 |
15X10 with 5 inch backspacing and P315/60-15's with a 6 inch rear drop.
