Old 07-30-2007, 07:25 PM   #1
Rat72
Rat72's Avatar
205 Shifter Upgrade?
Has anyone found a good upgrade for the 205 shifter? I saw one on eBay that had a bearing in it and a greasable bolt. eBay I'd really like to find another one like this. There seems to be plenty of twin stick units now but I really have no need for one and they just use up more space.
Thanks,
Whit
Rat72 is offline   Reply With Quote
Old 07-30-2007, 09:46 PM   #2
eedgell
It's the air up here
eedgell's Avatar
Re: 205 Shifter Upgrade?
I dont know much about after market shifters, but my 79 3/4 ton has a greasable linkage as factory for the 205.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 07-30-2007, 09:53 PM   #3
Rat72
Rat72's Avatar
Does it have a bearing or bushing where the bolt goes through it? More importantly, does it rattle? Thanks.
Old 07-31-2007, 01:00 AM   #4
earl87gta
earl87gta's Avatar
Im using a cable shifter on my divorced 205 case dont see why you couldnt do it to the regular case as well .
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 07-31-2007, 12:36 PM   #5
Rat72
Rat72's Avatar
I was toying with the idea of finding an electric shift mechanism from a new vehicle and adapting it. But all that seems like a lot of work if all I'm looking for is a quiet shifter. My Atlas II shifter doesn't make any noise.
Whit
Old 07-31-2007, 03:31 PM   #6
68K20 x Drill
http://quad4x4.com/New%20Process%20N...fer%20Case.htm
scroll to the bottom , then back up till you see anti rattle clips.
You can drill your existing bolt for a grease fitting, or buy one.
I also made mine a plastic washer using a yogurt lid.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 07-31-2007, 09:42 PM   #7
eedgell
eedgell's Avatar
Mine is a bushing, not a bearing. No it does not rattle. Hard to wear out linkage that moves inches with a zert.[if you grease]. My 71' has no zert, and does'nt rattle either.
Eric
Old 08-10-2007, 02:01 PM   #8
prg machine
prg machine's Avatar
The washer is one of many good upgrades ( I like the ingenious use of the yogurt lid!) I have shimmed the side play out of a few in Jeeps and made up a grease bolt with a zerk like above. All work good. It is all about getting the play out.
prg machine is offline   Reply With Quote
Old 08-10-2007, 10:25 PM   #9
earl87gta
earl87gta's Avatar
you can go here to and by the greesable bolt for 20 http://www.jkwoffroad.com/offroadproducts.php
Earl
