rearend cover
I bought a Moser rearend cover and it looks great. The only problem is the panhard bar hits the cover. Has anybody had the same problem. I would hate to have to remover the cover and put the old cover back on. Any suggestions on how to fix this problem. Thanks Mike
71 Chevy Stepside 377/350 |
Re: rearend cover
what kind of cover is it? chrome? aluminium? cause if its painted or polished steel you can always mod it yourself with a bit of cutting and a small piece of tubing, providing itll still clear the gears
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Re: rearend cover
It's an aluminium. It's hitting the load bolt for the main caps.
Re: rearend cover
so its not that its to deep thats the problem its that its to shallow? if its to shallow then you just need a different cover
Re: rearend cover
Without seeing pictures of your problem I can only guess at the exact problem. This issue was covered in the most recent issue of Classic Trucks magazine. Their solution was to go to CPP and get a modified panhard bar that bends around the cover. I checked the Classic Trucks website for a link to the article but could not find it.
Re: rearend cover
What issue of Classic Truck is it. Maybe I can try and find it in the stores. I also looked on the website and couldn't find anything. I don't know how it bends around the cover. I'm willing to try anything.
Re: rearend cover
It is the September 2007 issue. The name of the article is "Simple C-10 Solutions".
67 is sold
Re: rearend cover
I had clearace issues with the adj panhard bar on my 6" rear drop. I ended up using an OEM cover and painting it black
