Old 07-30-2007, 10:23 PM   #1
70C10Toejam
Hellasick
70C10Toejam's Avatar
how much to pay for an alignment???
since i finally got my PS done, (after installing my '85 disks)i'm now in need of an alignment.
The toe is off as is the camber(rides on the outer edge of the tires). how much can I expect this to cost me???? should really only be removing shims and adj. the toe.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 07-31-2007, 08:09 AM   #2
youngrodder
youngrodder's Avatar
Re: how much to pay for an alignment???
Around here (MI) an alignement will run you between $40.00 - $50.00. You might be able to find it for a little cheaper, but that is a pretty good ball park.
If it is a little out or a lot out of alignement, shops will still normally charge the one set price. Ask around for quotes. It is always best to do your homework.
Good luck.
Marc.
youngrodder is offline   Reply With Quote
Old 07-31-2007, 08:17 AM   #3
jkade
jkade's Avatar
I just had mine done Saturday and it was $32
jkade is offline   Reply With Quote
Old 01-23-2013, 01:06 PM   #4
DM Garage
All I can say is you usually get what you pay for and an alignment is a lot cheaper than tires! Look for someone that's going to do it right not how cheap they are!
DM Garage is offline   Reply With Quote
Old 01-26-2013, 06:57 PM   #5
BigRed76
BigRed76's Avatar
A quality alignment in this area is $75-$100
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 01-27-2013, 12:50 AM   #6
andrewmp6
If your going to keep the truck for years firestone has a lifetime alignment now.
andrewmp6 is offline   Reply With Quote
