07-31-2007, 12:09 AM | #1 |
internal?external balancing of later model 350?
I just picked up a later model 350 that has an one piece rear main seal that has a external balanced flex plate on it but the balancer is not notched. I have heard that the later model 350s are externally balanced but is it done with just the flex plate and not the balancer ?
07-31-2007, 10:03 AM | #2 |
Fabricate till you "puke"
Re: internal?external balancing of later model 350?
Yes, just the flexplate/flywheel. the balancer is nuetral balance. L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
