Old 07-31-2007, 07:29 AM   #1
beaterC10
Windshield washer questions
I am trying to get the windshield washer on my 86 working again and I need some help.
Does anyone know where I can get the rubber tubing that connects the wiper arm squirters to the fittings in the cowl? I tried the local parts stores and all they have is vacuum tubing, which is too large on the OD.
How long should it take for the pump to get fluid to the squirters? Mine takes several sweeps of the wipers before any fluid appears on the windshield. Newer vehicles seem to be quicker, wasn't sure if this is normal for an old truck.
Thanks.
beaterC10 is offline   Reply With Quote
Old 07-31-2007, 11:19 AM   #2
Zoomad75
K5Camper
Zoomad75's Avatar
Re: Windshield washer questions
You probably have a worn out pump. You can buy a rebuilt kit at most parts stores. I've found on my 75 K5 that the mechanisim that drives the pump from the wiper motor can wear out over time. I've rebuilt mine a couple of times to only have it stick and pump whenever the wipers are on, or not pump at all.
I got fed up with it and swiped a bottle off of a 93 S10 Blazer with an electric pump from the junkyard. By using the wiring that controled the solonoid on the factory mechanical pump my electric pump still works with the stock switch. So from the dash it works the same, but now it pumps fluid 5 times better than the stock crap would. If I aim the squirters right I can shoot over the roof and hit the next car behind me at a stoplight.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 07-31-2007, 11:21 AM   #3
sknights
I found my tubing at Ace hardware. Mine also takes a couple of passes before it sprays. HTH
sknights is offline   Reply With Quote
Old 07-31-2007, 12:11 PM   #4
beaterC10
Thanks for the help. I'll try Ace on the way home this evening.
Old 07-31-2007, 05:50 PM   #5
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
autozone help section'
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 07-31-2007, 06:28 PM   #6
Prerunner1982
Prerunner1982's Avatar
Mine went out and I just wired up a cheap replacement pump, its louder but worked just fine. I installed it the same time I added the squirters to the wiper arms.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 07-31-2007, 06:38 PM   #7
Srubydo1986
The Crazy Machanic
mine would squirt over the hood and that was fun at car shows
newest additions
Old 07-31-2007, 07:46 PM   #8
beaterC10
I checked Ace, Advance, O'Reily, Pep Boys, and Carquest and came up short on the hose. I found it in the LMC catalog and then I rummaged through my parts collection and found nicer wiper arms than were on the truck with good hoses and squirters.
I found a new pump at Carquest so I guess the problem is solved.
Old 08-01-2007, 12:50 AM   #9
tyjoja
got a washer pump rebuild kit and tubing at LMC. fairly priced
tyjoja is offline   Reply With Quote
Old 08-01-2007, 08:29 AM   #10
Phuloi68
I got some hose from a GM dealer parts dept. It was cheap and the right size.
Phuloi68
Indy survivor
Norwood survivor
Big Sandy survivor
for those who fight for it...
F R E E D O M
has a price the protected
will never know.
Phuloi68 is offline   Reply With Quote
Old 08-01-2007, 12:06 PM   #11
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Vacuum tubing will work, just get small diameter one - I got mine at Murray's which is in the same chain as Advance Auto and O'Reily - they sell it by the foot too, so buy as much as you want. There's no need for fancy GM hoses and such, as GoodYear vacuum ones work just fine.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
