Old 07-31-2007, 09:09 AM   #1
bryanw1968
bryanw1968's Avatar
Vacuum canister question......
I just installed a vacuum canister to help out with my power brakes.
I noticed that when after I cut the motor off it still holds vacuum. Is that normal?
bryanw1968 is offline   Reply With Quote
Old 10-21-2010, 11:27 PM   #2
60apache
60apache's Avatar
Re: Vacuum canister question......
yes because there is a check valve there to hold vacuum
60apache is offline   Reply With Quote
Old 10-22-2010, 06:48 AM   #3
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
bryanw1968 Do you have any pictures of your Vacuum canister installed I have one on my truck but I haven't hooked it up Im still looking for ideas of where to put it or maybe buying a different one as I think its too far. I mounted it on the fender near the rad support with a blazer charcoal canister mount.
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 10-22-2010, 12:00 PM   #4
Alex Hayley
Petey, Even though I was not asked, I mounted my vacuum canister just under the master cylinder slightly toward the engine on the inner fender. The vacuum lines travel nicely from behind the carb, to the vacuum canister and then on to the booster.
Alex Hayley is offline   Reply With Quote
Old 10-22-2010, 02:32 PM   #5
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Bought mine from Classic Parts, Petey I installed mine back in it's original place, from were the PO had removed it.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
