Old 08-01-2007, 02:48 AM   #1
bigblock79
67 Chevy Stepside
bigblock79's Avatar
flip kit with 2 piece drive shaft ???
5 in up front and a djm 5 inch flip kit out back will it work with my 2 pice drive lin thanks
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 08-01-2007, 02:37 PM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: flip kit with 2 piece drive shaft ???
DJM recommends changing to a 1 piece driveshaft, or modifying the bearing frame support.
http://djmsuspension.com/Instructions/Flip/FK1024-5.pdf
Malo83 is offline   Reply With Quote
Old 08-01-2007, 03:23 PM   #3
knightlife
Dark Heart Motorsports
knightlife's Avatar
thx malo...I was wondering the exact same thing...
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 08-01-2007, 03:46 PM   #4
boatpuller
boatpuller's Avatar
here's what i did......just like malo said.....i modified bearing bracket.driveshaft is now fairly level. no vibes or shudder up to speedo pegged he cut out stock bearing bracket welded in flat plate and bolted carrier bearing to it.not a very good pic.but,you'll get the idea.i really had some screwed up looking looking angles till we did this mod.i was gonna go to a single. but ,my exhaust guy said lets try this first.if it works its cheaper than a driveline.works excellent.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 08-01-2007, 04:16 PM   #5
Rc 415
Flat Black, & Chrome!
Rc 415's Avatar
What trucks came with 2 piece driveshafts?
1983 Chevy C10 Stepside Sold
http://s69.photobucket.com/albums/i76/rc_415/
Rc 415 is offline   Reply With Quote
Old 08-02-2007, 12:31 PM   #6
bigblock79
67 Chevy Stepside
bigblock79's Avatar
thanks boatpuller
1967 Chevy stepside
Old 08-02-2007, 03:34 PM   #7
boatpuller
boatpuller's Avatar
Originally Posted by bigblock79 View Post
thanks boatpuller
no problem .i know it was a little confusing for me when i looked under there and saw those messed up driveline angles.unless you've seen it nobody understands.alot of people never heard of 2 peice shafts on shortboxes.if you want some better pics let me know.
Old 08-02-2007, 03:38 PM   #8
boatpuller
boatpuller's Avatar
i think.(kinda scary,huh?)..........most big block and the diesel's.mine was a diesel.iv'e also been told.alot of the th400 trucks. which makes sense with the bb,diesel thing.also was told there's no real pattern.a buddy of mine who's had a shop for years,said he's seen em in all configurations.
Old 08-02-2007, 04:24 PM   #9
Dragster66ss
Dragster66ss's Avatar
FWIW:
My 77 gmc is 454/th400 and has 2-piece ds.
Lee Roberson
'77 Sierra Classic 454/th400
Other toys (Non P/U's):
67 Chevelle 427/m22 (My street ride)
3 1966 chevy II drag cars (fam racing operation: pop, lil-brother, and myself)
Dragster66ss is offline   Reply With Quote
Old 08-02-2007, 04:34 PM   #10
bigblock79
67 Chevy Stepside
bigblock79's Avatar
my 79 454 400 has it
my 79 305 400 has it
and that is the first time i had ever seen a 305 with it
and my 79 305 has a 8.88 ring gear on the options sheet
1967 Chevy stepside
Old 08-02-2007, 05:25 PM   #11
knightlife
knightlife's Avatar
ok Im usually wrong, but here goes:
boat ol buddy...
1. did you just move the carrier bearing to the side of where it was?
2. if so, did it interfere at all with your old exhaust setup?
3. you said he welded a plate onto it, how thick? and did he predrill it?
thx mang
Old 08-02-2007, 06:24 PM   #12
boatpuller
boatpuller's Avatar
boat ol buddy...
thx mang
your not wrong,your just learning. you know i wasn't there when he did it.what i would try if, physically able.i have a bad back and can't do the underneath stuff anymore.loosen the bearing from its mounting point to the frame and just pull the line at the rear or front and see if it will slide over enough to allow you to get up in there and cut out the stock perch.if not,you'll have to pull the line out .the plate,going off memory is 3/8's.and ,i'm not sure on the predrill.i had the exhaust guy do it on his lift with all the right stuff.welder,torch.i have had him do alot of custom exhaust stuff for me on other stuff.so,he gives me a pretty good deal.he knows i like em loud and i'll be back.i think you can visualize that raising that bearing up will fix your bad angle.check these new pics.man that flash picks up all the grease and oil under there doesn't it?
Old 08-02-2007, 09:56 PM   #13
knightlife
knightlife's Avatar
awesome...thanks man, you have no idea how much this will help my slam lol... curious tho...did he have to trim any of the bed cross members?
thanks again!
Cruor
Old 08-02-2007, 10:40 PM   #14
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
my 1986 witha 305 and a 3 speed granny came with a 2 peice drive shaft
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 08-03-2007, 01:36 AM   #15
boatpuller
boatpuller's Avatar
thanks again!
Cruor
nope.....
Old 08-03-2007, 05:51 PM   #16
bigblock79
67 Chevy Stepside
bigblock79's Avatar
thanks i put it on the ground last night and you are right it had some weird angle but will do your trick to it
1967 Chevy stepside
Old 08-03-2007, 06:08 PM   #17
Pyrotechnic
Pyrotechnic's Avatar
Mines at stock ride height all around, but I switched to a 1 piece since I had one from a previous truck that had all new u-joints and was balanced. Those rivets on the carrier bearing bracket took forever to grind off. I turned a large cutting wheel down to the size of a quarter after the 4th one. Then I had to smack it hard with sledge hammer to get it out. Those are some serious rivets. I didn't even bother taking the top portion of the rivets out of the cross member because they also very tight in the holes.
Pyrotechnic is offline   Reply With Quote
Old 08-03-2007, 07:03 PM   #18
knightlife
knightlife's Avatar
mine is bolted in lol....when I got my truck, dad and I went to the junkyard and picked up the drive shafts, carrier bearing, and the rear end already removed...then bolted her all in...I shouldve done the drop right after I got her...but yea, tax money only stretches so far lolz
Old 08-03-2007, 11:25 PM   #19
bigblock79
67 Chevy Stepside
bigblock79's Avatar
a touch gets them out quick
1967 Chevy stepside
