Old 08-01-2007, 12:31 PM   #1
dbcox
dbcox's Avatar
New ORD flip rear shackles installed
I finished them this morning I put them on a 83 3/4 ton longbed 4wd after a test drive i love em. The whole truck rides smoother and i dont have all that squeakin and popping i did with rear blocks.It sits a little higher in the rear thay make a front shackle that will cure that. I fell it was money well spent and they look cool to
dbcox is offline   Reply With Quote
Old 08-01-2007, 01:52 PM   #2
62 short step
62 short step's Avatar
Re: New ORD flip rear shackles installed
Have some pics?
62 short step is offline   Reply With Quote
Old 08-01-2007, 05:06 PM   #3
dbcox
dbcox's Avatar
a few i already put my truck up. here goes
Old 08-01-2007, 06:23 PM   #4
62 short step
Looks good, I would like to put some on my 61 4x4 but nobody makes them for 60-66 4x4's. I wonder if the 67-72's would work on my truck? Oh well, nice job!
Old 08-01-2007, 06:59 PM   #5
dbcox
dbcox's Avatar
thanks, i found the instructins after i was done they said the shackle should be turned around,not sure why it does the same thing i called but stephen was busy hes very helpful. Wonder if you had the measurements if you could make them work on your truck? i am releived to get the blocks out,i also gained some exta wheel travel with a smoother ride.
Old 08-02-2007, 10:33 AM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
Can you compare your rear axles front spring hanger to one from a 67-72? Worst case scenario, you might have to use 67-72 rear axle front spring hanger.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-02-2007, 04:28 PM   #7
62 short step
I thought about changing all the spring hangers to 73-87, but I guess the 67-72 would be the closet. The only thing is to find them, the salvage yards around here crush all the old stuff to quick!! I don't have any one around here that I know of that has a 67-72 4x4 to campare the front hangers to. I'll guess I'll have to search a little harder!! Jeremy.
Old 08-02-2007, 07:37 PM   #8
dbcox
dbcox's Avatar
i think the spring width from spring to spring may be an issue also
Old 08-02-2007, 08:38 PM   #9
62 short step
How wide are the springs on a 67-72 4x4? Mine are 2 1/2 inches wide. By the way I did not mean to hi jack your thread, sorry.
Old 08-03-2007, 02:50 AM   #10
72armyswbtruck
72armyswbtruck's Avatar
Those are nice, so how much did they cost?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 08-04-2007, 01:49 AM   #11
DESTRO
Ooooh I want some!
DESTRO is offline   Reply With Quote
Old 08-04-2007, 07:28 PM   #12
dbcox
dbcox's Avatar
the shackles are 189, the ubolts are 20,and shipping all was close to 250.
the results you get.....priceless
Old 08-05-2007, 12:30 AM   #13
CrashEd
72 chevy
CrashEd's Avatar
Them do look nice i always do the cheap way.
Name:  Picture 23551.jpg
then weld braces in
Name:  Picture 235512.jpg
but yours look so much better and heavier built
Ed
CrashEd is offline   Reply With Quote
Old 08-07-2007, 12:38 PM   #14
bufmatmuslepants
Junior Member
ed, the "cheap way" doesnt look that bad at all, has it ever failed on you?
1979 K10 reg cab short bed 33x12.50s - GONE
1988 4x4 reg cab long bed 337k miles - GONE
1995 Z71 GU6 G80 F44 ext cab short bed 149k 305/70/16s - GONE
1995 NZZ GT4 2dr Tahoe 3" lift 14 bolt sf 155k 305/70/16s - GONE
1994 Z28 M6
1995 Z71 GT4 G80 ext cab short bed 215k GONE
1997 GT4 G80 Yukon 4 door leather, sunroof 168k miles GONE
2003 Avalanche Z71 GT4 G80 165k miles
bufmatmuslepants is offline   Reply With Quote
Old 08-07-2007, 06:43 PM   #15
mothertrucker424
mothertrucker424's Avatar
i was lookingg at my truck how about if i took and cut right side and flipped it for the left side and cut left and put on right and added a longer shackle wouldn.t this get me a cheap set of shackle flip?
mothertrucker424 is offline   Reply With Quote
Old 08-07-2007, 07:14 PM   #16
CrashEd
72 chevy
CrashEd's Avatar
Thats the simplest and strongest way i have found the way i did mine but i think next time it will be one of them ORD shackle flips there cool.
Ed
Old 08-07-2007, 10:29 PM   #17
Zoomad75
K5Camper
Zoomad75's Avatar
I'm not sure of the homebrew flip and this is coming from one cheap SOB. I'm sure cutting a hole out of a stock hangar takes good amount of strength out of it. The added gussets help but it sure looks iffy.
You want a cheap way to do a flip go find a 2wd truck and swipe the rear spring front hangars from a junker. Put them in the rear. It just requires a lot of rivet cutting..
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 08-09-2007, 09:41 AM   #18
bowtier
Nobody rides free
bowtier's Avatar
Look good. Had a chance to try them out yet?
Just thought I'd link this again, to show another option. Some other links in that thread too.
http://67-72chevytrucks.com/vboard/s...d.php?t=190177
Shackle flip was the best upgrade I've made, really helped the flex.
'71 C10 LWB 400SB/350TH
'86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck
'06 HHR - wifes wheels
'01 Blazer - daily driver
"It's better to burn out than it is to rust."
-Neil Young
bowtier is offline   Reply With Quote
Old 08-10-2007, 04:38 AM   #19
DURRTY
USMC
DURRTY's Avatar
Attachment 288339
then weld braces in
Attachment 288340
Ed
Outstanding ED! thats genius and SO simple. I have been studying pics of those things for a week now trying to copy or make something similar.
Semper Fi
DURRTY is offline   Reply With Quote
Old 08-24-2007, 07:31 AM   #20
mothertrucker424
i am going to attempt to use the front shackle mount in the rear leaf to do a homemade shackle flip . can i use any year mount?
Old 08-25-2007, 01:06 PM   #21
DURRTY
USMC
DURRTY's Avatar
As long as it is the same width I don't think i matters were it is from. also check the diameter of the bolts and bolt holes
Semper Fi
