08-01-2007, 05:38 PM | #1 |
runs and then stalls
I finally have my truck running at idle. The only problem I am having for the time being is when I drop my truck into reverse the engine dies out on me. Any ideas?
08-01-2007, 07:39 PM | #2 |
Re: runs and then stalls
put it in neutral and push it, lol
whats the idle rpm when the truck is in park/neutral ?
Justin 1970 c/10 short wide bed WTT 1970 chevy front end for 67/68 chevy front end WTT 2 15x10 american racing outlaw 2 wheels for 2 of the same in a 15x7 or 15x8
08-01-2007, 07:47 PM | #3 |
Vacuum leak comes to mind, but you said when you drop it in reverse. Does that mean it doesn't die going into drive??? That would be a wierd one!
_______________ Thomas '78 Silverado '74 Monte Carlo '47 Teardrop Trailer East Texas Classics Local Club |
08-01-2007, 07:57 PM | #4 |
Active Member
Could use a little more info... automatic, v8, 4 barrel, etc... If automatic, check all the vacuum lines as stated.
Not sure if yours has idle advance but I had a carb that was not advancing the idle when placed in drive. It would die out on me. Problem is I don't remember what I did to fix it... I'll look thru some of my old repair manuals... |
08-01-2007, 07:58 PM | #5 |
need more info to properly guess on what it is
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
08-01-2007, 08:25 PM | #6 |
its all about the +6 inches
more info would be nice, but I'll throw out two common problems;
Timing not set right idle too low. I've seen late model fords that would die when you put it in reverse... this is mostly in the fuel injected F-150 trucks with the 4.9 inline motor... it's a sign of the tranny going out. But, that doesn't apply here. |
08-01-2007, 08:31 PM | #7 |
check for cracked broken vaccume lines/ set the dwell then the timing clean and gap the plugs change air and fuel filters// thats some of the more common things required
