The Original HotRod KnifeMaker
![]() Join Date: Jan 2007
My VR ram air unit sits so low that it interferes with my throttle linkage.
A spacer I found is 1.5 inches tall with the smog hose connection. That solved the problem with the throttle linkage. Now when I close the hood it puts slight pressure on the back of the ram air box and binds up the choke forcing it locked open. Does anyone have [or know of a place that sells] a 1" spacer w/smog tube? I have checked Summit and Jegs and most of the other on-line parts house and can find ony the spacers, none with the smog tube. I would prefer not to add a smog tube to the ram air itself. I guess the correct name for this part is an air cleaner spacer. Guess the Carb Spacers are the one under the carb- not what I need. TIA
Dave 69 GMC SWB 2WD 454 Turbo 400 Last edited by WinDancer; 08-02-2007 at 01:08 AM. Reason: clarification |
Re: Wanted- 1" 4bb carb spacer w/smog hos connection
can you cut down the spacer you have?
Mario and Mandy Hughesville, MD 20637 69 C10 305/350 71 K5 Basket case 75 K10 Rescue **Parting out** 77 MG Midget **Parting out** 15 6.7L Cummins |
It would be a hassle- there are locking pieces on the top and bottom. After cutting it would require that those rings be rebuilt to complete the lock between the carb and the Vararam. The rings fitting is critical to allow the choke to move fully.
I may end up cutting a half-inch from the very center of the riser and then re welding it back together. Sure would be simpler to just buy the part I need ![]()
Dave 69 GMC SWB 2WD 454 Turbo 400 |
"Trucks with Class"
![]() Join Date: Jul 2000
I have a neat 1" aluminum spacer. Sould work good.
PICKMUP, I sent you a PM asking if your part has the smog connection on it?
"Trucks with Class"
No smog connection...
