Old 08-02-2007, 08:02 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Exhaust for my 84
As some of you know I am in the process of swapping out the 305 in my truck for a 454. The current exhaust set-up is crappy bc it hangs below the frame. I only have a single hump tranny x-member. Has anyone fabricated their own xmember? Can I get some pics of the exhaust under the truck and doem side shots? What headers are you big block guys using? I want my exhaust fully tucked in the frame if possible, I got tired of hitting the headers in my old truck. My plans are to try and fit a x-pipe in there with 3" tubing/mufflers. The truck will be lowered at least 4/6.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 08-02-2007, 12:34 PM   #2
streetstar
streetstar's Avatar
Re: Exhaust for my 84
Doug Thorley headers are highly regarded
streetstar is offline   Reply With Quote
Old 08-02-2007, 07:09 PM   #3
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
No '84, but still a single-hump tranny crossmember - solution to my problems turned out to be in the form of Headman Hedders S-pipes. If I were to run a crossover and I had a garage I'd drop the tranny crossmember, get another one off a junker truck, cut both in half, match them up and weld them back again, so I end up with one double-hump crossmember and one double-dip crossmember. Which one I use would depend on the headers - high headers (like I currently have) would get the double-dip crossmember as the exhaust would have a straight shot towards the back along the tranny and over the crossmember, low headers would require use of the double-hump crossmember as piping will need to be routed under it. Hope that helps:
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
