Old 08-02-2007, 11:06 PM   #1
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Wink need steering help on 4x4
not sure if this is the right section, but here goes: I swapped out my 1/2 ton suspension and axles on my '67 burb for the 3/4 ton axles and suspension from my '68 GMC truck. Everything went ok, but now I'm having trouble getting the steering arm, I think that is what it is called, back into the axle knuckle on both trucks. Doesn't seem to want to hammer in or press in. I tried pressing it in with the 4 studs/nuts that hold it in place with no success. Any tricks or help would be appreciated. Thanks
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 08-02-2007, 11:09 PM   #2
Mudder
Mudder's Avatar
Re: need steering help on 4x4
You will get better answers for this question here. If you look down a little ways you will probably find you answer.
Mudder is offline   Reply With Quote
Old 08-03-2007, 07:39 AM   #3
Mudder
Mudder's Avatar
Are you sure it's the right one?
Old 08-03-2007, 09:53 AM   #4
Burt4x4
Burt4x4's Avatar
Pics?
I'm not sure I understand your problem?
Maybe I need more coffee
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 08-03-2007, 10:28 AM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
I'm not to clear on this either. Is it a D44?
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-03-2007, 08:02 PM   #6
msgross
msgross's Avatar
If original then it's closed knuckle dana 44 with four bolts holding it on. I took mine right off and put it on with no issues....
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-07-2007, 01:17 PM   #7
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Thanks guys for all the concerns and info, but I figured it out. Seemed to be more of an alignment problem, getting a round peg in a square hole type thing.
