Another Blazer tank swap Q for LWB trucks
I have a Blazer tank to put in my '69 LWB, I have read the entire FAQ section on the install. I still have a question as to the rear crossmember. For the tank to fit between the rails it looks as if I will have to cut out the rear crossmember, the one where the tail light harness runs into. I have a reciever hitch bolted to the frame so I'm not worried about rear support being an issue. I have the sender, straps and fuel line....oh, and sawzall in hand
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
Re: Another Blazer tank swap Q for LWB trucks
i'm not sure about your tank because i know it's a different style, but my longbed fleetside required removing the cross-sill on the bed. pics say more
i ordered the kit from lmc,and im hoping all i have to do is cut the brace between the back to frame rails,run line, run wire and be done.good luck with the install
Justin 1970 c/10 short wide bed WTT 1970 chevy front end for 67/68 chevy front end WTT 2 15x10 american racing outlaw 2 wheels for 2 of the same in a 15x7 or 15x8
oh yea there was a spare tire crossmember or something i cut out from the frame
maybe that is what it is, a spare tire crossmember? I know I will have to cut the bed support brace, no problem there. I shall attack it with the sawzall when I get home today..!!!
