Old 08-03-2007, 08:46 AM   #1
Batman
TH350 short shifting
I did some searching and couldn't find this exact problem with my TH350. So, hopefully there are some good tranny guys here.
If I let the transmission shift on its own it shifts very short, into second at 20mph and 3500RPM, 3rd at the same RPM and 35mph. Not really sure what gears I have, running 33" tires. It doesn't feel like it's slipping at all if I manually shift it I can wind it up and it doesn't seem to complain. I've adjusted the TV cable over and over, the vacuum modulator is in fine shape and adjusted for the highest possible shift (from what I gather this is only good for 2-3mph). I'm pretty close to just having it rebuilt, I don't think its ever had a rebuild. Anyone have an idea, if I can get away with not rebuilding it for a few years I'd like to.
1972 GMC K1500 350 V-eight TH350 4x4.
Batman is offline   Reply With Quote
Old 08-03-2007, 08:53 AM   #2
OLDIRON69
Re: TH350 short shifting
Bad modulator valve? You were looking for tranny experts though...that I'm not, but have had the same delima.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 08-03-2007, 09:12 AM   #3
68gmsee
Active Member
68gmsee's Avatar
I had a vehicle that did that once for many years and I never had any problems driving it around town. It would shift 1st to 2nd very quickly. A trans guy told me to check for any vacuum leaks since the modulator was vacuum controlled but I couldn't find any...
Since you say you're clost to a rebuild anyway and unless it becomes a problem like when towing or hauling, I'd just drive it.
68gmsee is offline   Reply With Quote
Old 08-03-2007, 09:22 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Forgot to mention, he also told me could be torque converter problem???
Old 08-03-2007, 01:10 PM   #5
Batman
I spent a lot of time searching for vacuum leaks too, haven't turned up anything. Torque converter problem? Something with it stalling too soon, I believe the torqueconverter is only a few years old in this truck, could this be a symptom if the TC happened to be a lockup TC, I know the tranny is non-lockup?
Old 08-03-2007, 01:16 PM   #6
AH619
AH619's Avatar
WHERE YOU HAVE YOUR MODULATOR PLUMBED INTO MAKES ALL THE DIFFERENCE. IT CANT HAVE CONSTANT VACUUM. IN OTHER WORDS IT HAS TO BUILD VAC AS THE ENGINE BUILDS RPMS. IF BY CHANCE YOU ARE PLUGGING INTO AN EDELBROCK ON THE DRIVERS SIDE PORT IN FRONT IT WILL SHIFT VERY FAST AND SOFT. IF SO LOOK AROUND YOUR LOCAL JUNK YARDS FOR A LITTLE DISC LOOKING THING IN THE MIDDLE OF A VACUUM LINE. MINE CAME OFF A EARLY 80S CHEVY PICKUP WITH A 305. JUST CUT YOUR VAC HOSE CLOSE TO THE END SO IF IT DOESNT HELP, YOUR HOSE WILL STILL BE LONG ENOUGH. HOPE THIS HELPS.
72 2wd lwb cheyenne super youngest son.green/white
72 2wd lwb cheyenne super oldest son.green/white
71 4wd 3/4 cheyenne super frame off manderin
copper / white 4 inch lift. FINALLY DONE / SOLD
72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO
REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR
COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856
AH619 is offline   Reply With Quote
Old 08-03-2007, 01:20 PM   #7
71chevylowrider
71chevylowrider's Avatar
I have a th-350 that was shifting waaay too soon, if I was just putting from a dead stop, it would shift into 3rd by the time I got to the other side of the instersection, I told a friend of mine who has rebuilt tranny's before & he came over with some little tiny springs, & we pulled out the governor off of the drivers side of the transmission & put softer springs in, that took care of it, & it only cost a couple bucks. Not sure if this is the same problem your having, but just thought I'd share my experience with you in case it's helpful.
71chevylowrider is offline   Reply With Quote
Old 08-03-2007, 01:36 PM   #8
OLDIRON69
My tranny is in the shop and called the guy that is rebuilding it, "modulator valve can be adjusted for a firmer shift" I will talk with him tomorrow when I pick my tranny up about the constant vaccum. Mine is hooked up to a vaccum source on the intake..did not know it wasn't supposed to have constant vaccum.
05 2500HD 6.0 excab
Old 08-03-2007, 01:42 PM   #9
Batman
I have a Wieand intake, the vac line comes off a big T in front of the distributor. Is the disc looking thing you refer to a vacuum check valve? If so those are easy to get at a parts store for a couple bucks, that should just hold vacuum when it drops, though.
Old 08-03-2007, 01:57 PM   #10
cdowns
cdowns's Avatar
first off you dont have a TV cable on a turbo350 its a kickdown passing gear cable has nothing to do with upshifting
second the shifts that you're describing when in the drive position sound completely normal for a stock tranny
Old 08-03-2007, 03:57 PM   #11
AH619
AH619's Avatar
The Vacuum Disc Fixed Mine. My Turbo350 Has A Stage 2 Shift Kit And Was Just Completely Rebuilt. My Tranny Man Told Me About The Disc And He Said It Would Hold Back Vacuum Untill A Certain Pont Was Reached And At That Point It Would Let Vacuum Through. He Also Said That You Could Tee Off Your 3/8 Brake Booster Hose With A Hose Small Enough For Your Modulator Valve And The Booster Would Use Enough Vacuum To Partially Starve The Modulator. When We Tested Mine Before I Got The Restricter Disc? We Swapped Hoses With Me Vacuum Advance Which Made My Dist Advance Fully Whenever My Truck Was Running Bit It Did Make My Truck Shift Harder. That Told Me There Was Nothing Wrong With My Tranny. So 1 Disc Later And Returning My Hoses To Correct Places Now I Get A Great 2nd Gear Scratch.this Is What Fixed My Truck. And Nye The Way After I Installed The Disc I Has To Readjust Me Modulator. I Had Also Messed With It.
Old 08-03-2007, 03:58 PM   #12
AH619
AH619's Avatar
Im Not Irish Just Cant Type.
