Old 08-03-2007, 01:33 PM   #1
bryanw1968
bryanw1968's Avatar
Finally got the truck weighed......
3648lbs with 1/2 a tank of gas in it.
bryanw1968 is offline   Reply With Quote
Old 08-03-2007, 02:08 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Finally got the truck weighed......
Featherweight!!
Mine came in at 5300# empty, but I can't recall how much fuel was on board... (it will hold more than 50 gallons)
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 08-03-2007, 02:17 PM   #3
bryanw1968
bryanw1968's Avatar
Yah mine is a short/narrow w/a wood bed and a 350/350.
Old 08-03-2007, 04:08 PM   #4
whatnow123
whatnow123's Avatar
I remember the last thread on this and I'm happy to hear this!! I figured my truck (SWB, stepside currently without a floor) couldn't possibly weigh the 42 to 4400 that some had mentioned.
I know I've got some extra weight (silverado seats is probably the biggest addition, not sure how much a 700R out weighs a TH350) but I was freaking out at some of the weights people were posting. I know I'm adding weight but at the same time I'll also reducing it as I'm being conscious of the weight of the truck as well. I'm going with roll pans which should save some LBS, one piece windows, aluminum radiator, but I'm adding power brakes, power steering, vintage air system, front sway bar, 4 wheel disks which should be lighter than drums so I'm not sure where my truck is going to come in at. I know 17in cast wheels aren't going help much at all either.
I was building the truck to be a decent runner and that last thread got me thinking crap, I'll bet my truck is 4600lbs, why did I go with a small block!
Anyway, thanks for getting your truck weighed. It made my day to hear it's well under 4000LBS and very similar to to mine.
Bryan, do you have any weight "adders" to your truck? I can't tell if you have bumpers etc...
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 08-03-2007, 04:17 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Have not weighed Merlot yet, but my old 67 street/strip truck was 3450
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-03-2007, 04:22 PM   #6
HeavyD
HeavyD's Avatar
These weights are no more than a late 60's Chevelle, so it can't be that hard to make these trucks fly.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 08-03-2007, 04:27 PM   #7
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
i guess if we can get it to hook up the back tires
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 08-03-2007, 04:30 PM   #8
bryanw1968
bryanw1968's Avatar
No problemo! Glad I could help.
I have added the following:
8" steel 4X4 rally wheels
Disc break conversion in the front(rotors, calipers, spindles...etc)
Front sway bar
Rear sway bar
Disc brake booster
Vacuum canister(aluminum)
Went from a 3 core to a 4 core radiator
Transmission cooler
And yes, I have front and rear chrome bumpers. They're actually not that heavy.
I had a hard time believing that I was going to be over 4000lbs too.
Good luck,
Bryan
Old 08-05-2007, 02:28 PM   #9
70C10Toejam
Hellasick
70C10Toejam's Avatar
weighed my truck two years ago when I got some dirt for my yard.
not sure how much gas it had in it. they left me as a cash pay under a large contractor, so I thought I should remove that info. 1.18 ton.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 08-05-2007, 05:33 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the disk brakes are typicly considerably heavier than drums. Just FYI.
Old 08-05-2007, 06:29 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Aha! That would explain my weight slip...
- Mike -
RIP El Jay
Old 08-05-2007, 06:57 PM   #12
jkeady
jkeady's Avatar
I weighed my '70 for the first time not long ago. With me (220-ish) and a half tank of gas, it came in right around 4750. I was really surprised that it was so light.
Like someone said above, the half tons are weighing in close to what a street car weighs. If the aero was a little better and you could get some of that weight over the rear wheels, these things could flat-out fly (some of them can, despite those obstacles. ) My '90 Tbird weighs in at 3700, and parked next to a pickup you would never guess that there is almost as much car as there is truck.
Josh
'70 Custom Camper / 20
jkeady is offline   Reply With Quote
Old 08-05-2007, 08:10 PM   #13
Longhorn Man
my old SWB was a few pounds shy of 4000, and my longhorn is just over 5000
