Old 08-04-2007, 02:39 PM   #1
aaronfab
aaronfab's Avatar
Ideal steering box
I had deduced from research that the '76-'80 power steering gear boxes where the best bolt in replacements for our trucks. (variable, 3 1/2 lock to lock, not metric hoses) BUT, I've heard rumor two separate places about using a late 70's Firebird steering box!?! Can anyone clear this up for me? I thought cars were mount inside the frame and trucks outside the frame. I just want to know what bolt in, quickest ratio, junkyard find, power steering box to look for? I know anything will be better than my MANUAL STEERING that I have now.
Aaron
Check out my site at:
http://aaronfab.com/
aaronfab is offline   Reply With Quote
Old 08-05-2007, 01:29 PM   #2
aaronfab
aaronfab's Avatar
Re: Ideal steering box
Anyone?...
Old 08-05-2007, 01:45 PM   #3
70C10Toejam
Hellasick
70C10Toejam's Avatar
best of my knowledge:
car boxes do not work cause they are inside the frame, not outside.
changed to metric/o-ring in '79.
if you do get a '79-'87 box, you can do this:
http://67-72chevytrucks.com/vboard/s...d.php?t=242458
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 08-05-2007, 03:21 PM   #4
mbgmike
I would use the 605 box (truck)
mbgmike is offline   Reply With Quote
Old 08-05-2007, 10:19 PM   #5
Green Machine
Green Machine's Avatar
Car won't work pretty sure. We used a PS box from a 1978 C10 to replace the leaky box on out 1971 C20. Had to swap the pitman arm of course, the old lines fit the box just fine. BUT - we had to use the rag joint from the 78, there is a difference in the diameter of the shaft on top. It does turn quicker than the old box.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 08-06-2007, 08:32 AM   #6
aaronfab
aaronfab's Avatar
Toejam, fellow Iowan,
Thanks for the info on the inserts, didn't know of that option.
Mike,
What is a 605 box?
Green Machine,
78 pitman arm? All of the 78 rag joint? "It does turn quicker than the old box." That's what I wanted to hear.
Aaron
Old 08-06-2007, 12:14 PM   #7
mbgmike
Mike,
What is a 605 box?
Green Machine,
t Aaron
Thats just what the truck box you are talking about is called. The newer trucks are 805 boxes
Old 08-06-2007, 05:10 PM   #8
Ironhead
Ironhead's Avatar
I converted my non-powered 68 to powered by bolting a power steering pump off a 1971 Caprice Classic. It's a direct bolt-in other than I had to bend the corner of the wheel well a bit due to the line interference. Works great.... Hope this is helpful.
Ironhead Mike
'68 Panel 402BB
'84 Shortbox 4X4
'85 Blazer
'97 Silverado Ext. Cab
Ironhead is offline   Reply With Quote
Old 08-06-2007, 07:21 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I'm curious.Are you using the 78 pitman also?
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-07-2007, 01:44 PM   #10
aaronfab
aaronfab's Avatar
Ironhead,
The pump is off a Caprice, but what did the gear box come from?
Aaron
Old 08-07-2007, 04:08 PM   #11
FingerTight
So there I was...
FingerTight's Avatar
subscribed, gotta do this on the '69
FingerTight is offline   Reply With Quote
Old 08-07-2007, 07:14 PM   #12
Ironhead
Ironhead's Avatar
Aaron - I converted over to p/s about 15 years ago & for some reason I was thinking used the entire set up from the Caprice when I pulled the BB motor out of it but I guess I was wrong. The only other gear p/s gearbox I would had around at the time would have been from a 79 blazer that I parted out & scrapped. Sorry for any incorrect info... If any help, here are numbers off the box 7802644 with 14 just below.
Ironhead Mike
'68 Panel 402BB
'84 Shortbox 4X4
'85 Blazer
Old 08-08-2007, 12:39 AM   #13
70C10Toejam
Hellasick
I didn't either, spent much time trying to get a custom line made(NO NONE could make one) and accidently taliked to the right person which led to searching for those. I just didn't want to throw out a good box over that problem, were $14 plus change ($4 each, $6 and change shipping). If you don't have a box, might as well get one with the flare fittings. But if you can only find a used metric box, great fix. None of the replacement metric lines would fit my truck.
Us Iweegans gotta stick together.
