Old 09-24-2002, 02:54 PM   #1
XXL
Seņor Member
XXL's Avatar
Question Pictures of BACK of gauge and bezel??
Anyone out there have a gauge dash sitting around? Can you take some clear pictures of the back of the dash. I'm trying to get an idea of whether I can use a gauge dash and take out/rearrange the small gauges. And, while I'm asking, if anyone has a picture of the back of an empty bezel, I'd appreciate that as well.
Thanks in advance,
Kenneth
XXL is offline   Reply With Quote
Old 09-24-2002, 03:09 PM   #2
wlee
Just an Old Mr Goodwrench
Here's a thread on the subject
http://67-72chevytrucks.com/vboard/s...threadid=24899
1969 CST 20 Longhorn
1970 CST 20 Fleetside
1991 Jaguar Sovereign
1992 Mazda Miata
wlee is offline   Reply With Quote
Old 09-24-2002, 03:27 PM   #3
XXL
Seņor Member
XXL's Avatar
Yes, thanks. The article scans are helpful, but the pictures are really tough to make anything significant out... hence my request for clear pics.
Thanks again,
Kenneth
Old 09-24-2002, 04:00 PM   #4
Smooth68
Smooth68's Avatar
I can hook ya up later today when Beer thirty comes around - I'll check back later tonight to see if you got hooked up.
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
Old 09-24-2002, 05:49 PM   #5
Gene
Gene's Avatar
Dunno if this is any clearer than what you have seen?
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 09-24-2002, 05:51 PM   #6
Gene
Gene's Avatar
empty bezel
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 09-24-2002, 06:39 PM   #7
67cst
i love summertime
67cst's Avatar
is it possible just to have the black plastic part to put after market gauges in? would the plastic be strong enough? or do you need the metal for strengh?
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 09-24-2002, 07:04 PM   #8
XXL
Seņor Member
XXL's Avatar
Actually yes, thanks! So what gauges go on the right side (left if you're looking at the rear) that are evidently under the little metal door? If I open that door up can I yank out those two gauges without messing with any of the other gauges or wiring? Where do those two get their wiring from? They don't appear to be on the PC board like the other two gauges.
Kenneth
Old 09-24-2002, 07:38 PM   #9
Gene
Gene's Avatar
I am assuming you are talking about the oil pressure gauge and the empty spot unless you have a vaccum gauge whis is unlikely? No I don't see why removing these gauges would hurt anything? And to answer 71 shortsteps question, I have seen people install gauges in a bezel without the oil pressure gauge and battery gauge. I have a couple of complete gauge clusters with the gauges in them laying around if anyone really needs one.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 10-07-2002, 01:25 AM   #10
XXL
Seņor Member
XXL's Avatar
I'm still brainstorming (or at least trying to ) about my gauge situation. Has anyone got a reallllllly clear shot of the back of an "idiot light" dash bezel? I'm tyring to get a sense of what it would take to machine an aluminum bezel that utilized the STOCK idiot light gauges.
And... anyone out there have a working set of idiot light gauges and bezel they want to git rid of (on the verrrrry cheap side, preferrably). Oh, and the bezel doesn't have to be the least bit pretty. I just need it to be basically intact so I can take measurements off the external edges, the 3 holes, and the various parts of the back where the gauges bolt up.
What I might need to do to pull this off is machine a flat bezel and cut the gauge mount part off the plastic bezel and epoxy it to the aluminum. That'd give me the mounts fairly easily.
Anyway, enough rambling. Must s l e e p !
Thanks,
Kenneth
Old 10-07-2002, 09:28 AM   #11
MStokes
MStokes's Avatar
Here is a fairly clear photo of the back of my dash.
1972 C-10 LWB, 400/350, 2WD
1972 C-20 Custom Camper, 350/350, 4WD (Converted)
MStokes is offline   Reply With Quote
Old 10-07-2002, 09:29 AM   #12
MStokes
MStokes's Avatar
And one of the back of my old and new fuel gauges removed from the bezel.
Old 10-07-2002, 10:29 AM   #13
XXL
Seņor Member
XXL's Avatar
Thanks. Those are VERY clear! Do you happen to have any such pics of the back of the actual plastic bezel??
Thanks again,
Kenneth
Old 10-07-2002, 10:38 AM   #14
MStokes
MStokes's Avatar
Sorry, but those are the only two I have from when I had everything apart. Good luck.
Old 10-07-2002, 11:24 AM   #15
vfrdude
vfrdude's Avatar
Why not take your gauge cluster out and have a look-see for yourself?????
Also, why go thru all the trouble of fabricating an aluminum bezel for IDIOT light gauges??? Seems like a perfect time to upgrade.....
Rudy Fierros
'95 Honda VFR750F
Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it!
vfrdude is offline   Reply With Quote
Old 10-07-2002, 12:01 PM   #16
XXL
Seņor Member
XXL's Avatar
vfrdude, I wasn't asking anyone to disassemble their dash for me. I was asking if anyone had photos of when they did disassemble, or if they had a bezel laying around that they could take a snapshot of. Barring success with the valuable resources this board offers in this area, I will indeed take mine apart, but I don't plan to reinvent the wheel if one of the members here has the info already.
As for the idiot light gauges, you assume that I want to "upgrade" to MORE gauges. I don't. I want 'minimalist' gauges, and am brainstorming for solutions to my specific needs.
Thanks,
Kenneth
Old 10-07-2002, 12:30 PM   #17
vfrdude
vfrdude's Avatar
Just curious...most people opt to have the gauges - they like to know what's going on with the motor, before something happens - for instance - idiot light will go on AFTER you lose oil pressure - as opposed to having a gauge where you are able to maybe see pressure readings that may clue you into something may be going south.... The gauge cluster has always been considered an upgrade, that is why I referred to it that way. Obviously, you don't consider it an upgrade, just clutter - everyone is entitled to their opinion...
Rudy Fierros
'95 Honda VFR750F
Old 10-07-2002, 01:35 PM   #18
XXL
Seņor Member
XXL's Avatar
Here's a shot of my dash in progress. This is a good example of the minimalist approach I'm taking on the whole truck--
Kenneth
Old 10-07-2002, 01:39 PM   #19
MStokes
MStokes's Avatar
Looks nice XXL. What are you going to do for heat/defrost/ac controls? Is there someplace else they can be hidden?
Old 10-07-2002, 01:51 PM   #20
vfrdude
vfrdude's Avatar
Nice work... it should look real nice, when you get it done.
Rudy Fierros
'95 Honda VFR750F
Old 10-07-2002, 01:53 PM   #21
XXL
Seņor Member
XXL's Avatar
No A/C. Heat/defrost will be an aftermarket unit that is self-contained behind where the glove box door used to be. The floor/dash selector is on the unit itself so a quick reach under the dash and I'm all set there. And the fan speed switch will also be just behind the dash so a quick reach and turn will get me going. However, I actually LOVE cold weather... and I've driven the truck here in MA for the last 2 years with the heater hose looped back onto itself. There have been a few days where it was downright COOOOOLLLLD thanks the the huge holes in the cab that's currently on the truck , but it's not usually a problem.
The 'hiding' issues I have are still pretty big though. I've got to find a place for 2 dual-needle air gauges, 6 rocker switches (4 control the 4 corner air bags, 1 the compressors, and 1 a combined dump of all 4 bags at once), as well as the ignition switch, lights, wipers, etc. And... to make matters more difficult, I won't likely have a console because I'm planning on recovering the stock bench seat. I may do something understated overhead or I may do some hidden pop-out doors in the aluminum bezel I described above. I'm still brainstorming some of this stuff.
Kenneth
Old 10-07-2002, 02:31 PM   #22
XXL
Seņor Member
XXL's Avatar
At work I only have stone knives and bearskins, so here's a verrrrry bad hack of one dash bezel idea. The trapezoidal panels are intended to be doors that fold down. So when you look at the bezel you'd see them, but if you folded them down, you'd see some of the other stuff I need to hide-- switches, air gauges, etc. It may be too impractical for actual use though. Hmmm...
Kenneth
Old 10-07-2002, 03:04 PM   #23
jay-dawg
chevelito
jay-dawg's Avatar
how about a vacuum actuated panel that will come down below the dash for the air guages and switches.
jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 10-07-2002, 07:57 PM   #24
XXL
Seņor Member
XXL's Avatar
jay
Good idea. About the time you were typing this I thought about something similar... just building a long panel that runs roughly across the middle 1/3rd of the dash. Build it so that it is under the dash pointing down. Then hinge it. As for motion, I'd do electric motor rather than vacuum as it's more stable. Hmmm... I think that's what I need to investigate. That way I can avoid cutting those trapezoidal panels in my diagram above. I think that would look funny (like, "hey, what's in there???").
Thanks,
Kenneth
Old 10-07-2002, 09:07 PM   #25
weasel29gm
SLOW BUT SURE,BUT CLOSER
XXL, is there any way you could use the glove box door idea on yours? By your design pic would the door be easy to modify?
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
