Old 08-04-2007, 06:05 PM   #1
boomer
87 gmc cab mount removal struggle
I got the 2 rear cab mounts out,rusty but the bolts screwed out.
The front is a different story. The passenger cab mount bolt will not come out because its spinning inside and i cant figure out how to get it out, i havent ripped the carpet up to see if i can see it but probably not because its spinning just under the cab piece that i cant get at.
boomer is offline   Reply With Quote
Old 08-04-2007, 06:21 PM   #2
C&C Chevy
C&C Chevy's Avatar
Re: 87gmc cab mount removal struggle
Never done it myself, but this might help.
http://www.73-87.com/7387garage/exte...b_bushings.htm
Always refer to 73-87.com for help!
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 08-04-2007, 10:29 PM   #3
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
if you want you can cut a hole in the floor above the bolt and get to it. best bet cut the bolt cut the floor but in a new nut and bolt the weld cut section of floor back in. Id say cut a circular hole with a die cutter/ it attaches to a dril i dont know the exact name.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
