Old 08-04-2007, 06:57 PM   #1
jorgensensc
jorgensensc's Avatar
Straight 6 block # question.
This is an 6 cylinder that is comeing my way for some work on a '69. Can someone tell me what the casting number on the block makes the engine? The number is 6 921966. THanks! Here is a pic:
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 08-04-2007, 09:23 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Straight 6 block # question.
Where did you get the number from?? Are you sure that is the engine code?
I think the number should be on the passenger side of the block behind the distributor.
Go to this site to get more info.
http://www.inliners.org/becks/BCN2.html
68gmsee is offline   Reply With Quote
Old 08-05-2007, 12:54 AM   #3
samwise68
FarmBoy.
samwise68's Avatar
measure the side lifter covers - 4" is a 230/250, and 6" is a 292. from the looks of it, it's a 230/250, which used the same block anyway. so, thats my guess atleast.
GMSee beat me to it, go to Inliners.org for some major inline info.
-Sam.
1969 GMC C1500. long fleet.
307. 3 on the tree. 3.07 gears.
Oliver green. Bent and bruised. Daily Driver.
Screw patina... it's a beater...Beaters are cool.
my build thread - Project Homebrew:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993
samwise68 is offline   Reply With Quote
