![]() Join Date: Jan 2002
Driveshaft Question
Hi
I have a 1972 chevy shortbox. It is a factory 350/TH350 setup and am planning on putting a 402 in it. I am going to leave the TH350 for now and was wondering if the driveshaft will work or if I need to get a different one. Thanks.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
Re: Driveshaft Question
Trans will not move so driveshaft will be the same.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Ttt
if youre keeping the same trans that came out then the same drive shaft will be fine
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
It should all work with no need for a driveshaft change,lenthen,or shorten as long as you dont move the motor positioning.
might want to check your clearance issues first. I had to move my motor/trans back 2'' when i changed from a small to big block and my fan still sits only about 3/4 inch from the radiator. But i used late model mounts and brackets, not sure how the origionals work. In my case i had to shorten the driveshaft 2'' as well. i went with a 1 piece out of a later model chevy shortbed thats larger around and stronger.
-Scott- 1970 C10 shortbed 396 1969 C30 dually flatbed "Vidalia" |
...............almost forgot, i also have a long water pump......
